20 Most Recent
Panasonic NN-T551 Microwave Oven Questions & Answers
The door closes but not firmly their is still
The door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
12/30/2010 1:04:49 PM •
Panasonic...
Answered
on Dec 30, 2010
How do I change the lightbulb in the Panasonic
Howdy. Bad news; that is not a user-repairable part according to Panasonic. They recommend a local repair shop. I was going to send you the link to the manual anyway, (in case you are a hardcore DIY person) but that model is no longer supported on Panasonic's site. Sigh.
If you have any trouble locating a decent repair specialist in your area, I'd be happy to help out with that.
Farmerbear at FixYa.com
9/13/2010 4:23:23 PM •
Panasonic...
Answered
on Sep 13, 2010
Microwave shut off after approximately 3 secs
Faulty Magnetron, Power Diode Power supply or both, this unit is shutting down due to one of these faults. I recommend that you get a "Quote" for a repair, this way you will be able to make a decision as to repair or replace. I must also add that MW are VERY dangerous to service. Unless special precautions are taken prior to servicing they can be lethal.
3/22/2010 5:41:59 AM •
Panasonic...
Answered
on Mar 22, 2010
I have panasonic NNT 551W
There is relay switches that lock door,when microwave is turned on
remove Lid and behind the display panel mounted to fame of oven you should see them unloosen them ,then push them forward retighten them back and see if unit works. Should be 2 of them 1 up top and 1 below it.
2/13/2010 11:37:52 AM •
Panasonic...
Answered
on Feb 13, 2010
I have a Panasonic genius dimension4 nn-9853
Most probably the low voltage transformer of in the control panel is open . It has a thermal fuse which is between pin1 and pin 5 of the low voltage transformer. This fuse is however inside the transformer. If you get a DC resistance of about 350- 400 ohms between pin 5 and 6 of the transormer , connect an external 500ma fuse between pin 1 and pin5
3/31/2024 3:01:10 PM •
Panasonic...
Answered
on Mar 31, 2024
Microwave Panasonic NN T551 new does not start even after pressing clock button , no display to set clock . Icon comes only. As : after pressing stop button. No other button gives any response
It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
- Power Cycle the Microwave:
- Unplug the microwave from the power outlet.
- Wait for about 30 seconds.
- Plug it back in and try setting the clock again.
- Check for Child Lock:
- Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
- Reset to Default Settings:
- If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
- Inspect for Physical Damage:
- Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
1/26/2024 4:53:36 AM •
Panasonic...
Answered
on Jan 26, 2024
