20 Most Recent
Panasonic NN-S768BA/WA Microwave Oven Questions & Answers
How can I obtain the
Many ovens are now built with "tamper-resistant" Torx screws. These have a center pin to keep a regular driver from fitting. You can buy drivers now at many stores or from online vendors. Sears has them, I think, and I know the Harbor Freight chain carries them if you have one near you. I just tried a search on eBay for "tamper torx" and there are a lot of vendors if you can't find them locally.
10/16/2012 8:59:38 PM •
Panasonic...
Answered
on Oct 16, 2012
No est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
1/24/2008 7:18:17 PM •
Panasonic...
Answered
on Jan 24, 2008
Microwave Panasonic NN T551 new does not start even after pressing clock button , no display to set clock . Icon comes only. As : after pressing stop button. No other button gives any response
It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
- Power Cycle the Microwave:
- Unplug the microwave from the power outlet.
- Wait for about 30 seconds.
- Plug it back in and try setting the clock again.
- Check for Child Lock:
- Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
- Reset to Default Settings:
- If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
- Inspect for Physical Damage:
- Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
1/26/2024 4:53:36 AM •
Panasonic...
Answered
on Jan 26, 2024
How do I cook an individual frozen pie in my Panasonic convection/grill/microwave
To cook an individual frozen pie in your Panasonic convection/grill/microwave, you can follow these steps:
Preheat the oven to 375°F.
Remove the pie from its packaging and place it on a microwave-safe plate.
Place the plate in the center of the microwave and close the door.
Press the "Convection" button on your microwave and set the temperature to 375°F.
Set the timer for 25 minutes.
Press "Start" to begin cooking.
After 25 minutes, check if the pie is cooked by inserting a toothpick into the center of the pie. If it comes out clean, your pie is ready! If not, continue cooking for another 5-10 minutes until it is fully cooked. This is a general guide and there might be variance with your particular device.
10/22/2023 4:43:39 AM •
Panasonic...
Answered
on Oct 22, 2023
When i press it display error in panasonic dimension 4 genuis model nn-c897wbbpq
An "error" message on a Panasonic Dimension 4 Genius model NN-C897WBBPQ microwave oven could indicate a problem with the electronic control system.
It is recommend to try resetting the microwave by unplugging it for a few minutes, then plugging it back in. If the problem persists, you should have the microwave checked by a professional technician.
You can also try to reset the oven by following the steps in the user manual, which typically involves pressing a certain combination of buttons on the control panel.
If the problem is still there, it is advisable to contact the manufacturer or a professional technician for repair. This will help you to get a more accurate diagnosis and a solution to the problem. Depending on the cause of the issue, the cost of repair can vary.
It is important to note that, error messages can be caused by various problems, so it is best to refer to the user manual or contact the manufacturer for more specific troubleshooting steps and to get a more detailed diagnosis of the problem.
1/18/2023 6:46:03 AM •
Panasonic...
Answered
on Jan 18, 2023
