20 Most Recent Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Questions & Answers
Float was stuck and it may be OK now , but were I you I would add a fuel line shut off and turn it to off between uses .
Poulan 42-Inch... | Answered on Feb 15, 2018
us
You can download manual from this site, it should have the belt diagram included.
Poulan 42-Inch... | Answered on Jan 18, 2018
wfm0qdj3e4hfqaaaaasuvork5cyii=
Poulan 42-Inch... | Answered on Dec 12, 2017
The filler is on top of the transmission, it is not easy to get access. The transmission will use 20W50 full synthetic oil. fill to within 25-30mm to the top.
Poulan 42-Inch... | Answered on Dec 07, 2017
Should be a "c" clip holding the wheel on. Pay attention to the washers and put them back on the correct sides of the wheel.
This model only has 1 spark plug. It is on the front of the engine, follow the plug wire to find it. The fuel filter is between the fuel tank and carburetor. If a new battery does not start the unit (first check the battery) you probably have a bad fuse. Located on the back side of the ignition switch. Trace the red wire and you will find it.
Poulan 42-Inch... | Answered on Nov 20, 2017
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Poulan 42-Inch... | Answered on Aug 06, 2017
perhaps a complete motor overhaul . oil rings may be broke .
Poulan 42-Inch... | Answered on Oct 06, 2016
When it shuts off what is it losing?
Poulan 42-Inch... | Answered on Aug 25, 2016
Just about all the smaller type engines the alt. can be found under the flywheel. The alt is a combination of both the flywheel and the stator ( the electrical windings ) atached to the engine block under the flywheel. Watch out...if you use a vehicle to jump your tractor, it will fry the stator if you the jumper cables on after it initially starts!
Poulan 42-Inch... | Answered on Jun 19, 2016
Make a drawing of the deck routing and pull the belt off the mower measure the width and length of the belt and order one on line or go to a mower shop with the belt and they can size it to the one you need. Do the same for the drive belt.
Poulan 42-Inch... | Answered on Apr 18, 2016
I need the diagram for a drive belt for a 42'' lawn tractor - 14.5 hp Can ANY ONE help me?
Starters have a solenoid that engages the starter with the engine when you push the start/run control. If the starter will not turn off once the engine "catches" then there's a problem in the electronics that keeps power to the solenoid and therefore, the starter.
You basically have to trace the wires back from the starter to see where they attach to the control, looking for a cut in the wire that would short it out to the chassis (that's not where it gets power because the chassis is usually ground) but damaged wiring is usually the easiest place to start because if you look carefully, its visible.
If wiring looks good, then go to your starter controller whether keyed or pushbutton or electronic. Even though manufacturers usually leave service issues to local dealers, talking to a tech is free and you may find a good idea there if the ones I gave you take you deeper into the problem without solving it.
The thing is Glenn, be patient and go slowly. Sometimes these electrical issues are tough to diagnose, so keep your eyes open and go step by step. I just finally solved an intermittent starter issue with a 2000 Expedition that took months to diagnose. Take your time and good luck! Chad
I’m happy to assist further over the phone at https://www.6ya.com/expert/chad_65e28e99f5372e81
Poulan 42-Inch... | Answered on Mar 21, 2016
Do a search on goggle for the make model and deck size and you can see the routing diagram.
Poulan 42-Inch... | Answered on Dec 17, 2015
CHECK BELT, WITH MOWER OFF ! . HAVE SOMEONE MOVE HANDLE UP-DOWN AS YOU WATCH THE BELT, IT SHOULD FEEL TIGHT WHEN DECK IS LOWERED .. JAY
Poulan 42-Inch... | Answered on Oct 09, 2015
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
461 questions posted
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
View Most Popular
Poulan Garden
  • Poulan Garden
Most Popular Question
engine shuts down during operation
  • Garden
