20 Most Recent Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Questions & Answers
0answers
Where is the flue/flame sensor located at on my Pentair master temp 400gas heater?
Hy my pulsar 150 slow running bymitake off I try start not start continue kiks after 10 to 20 munitus I again start plies my problem sove
10/7/2017 4:53:34 AM • Pentair MASTER... • Answered on Oct 07, 2017
0answers
2answers
Pentair Master Temp Heater is not heating and
Definitely bad thermistor Pentair reps have seen this happen a lot. Lick finger and touch the two contacts where the thermistor plugs in it should fire up if it's a bad thermistor. If you do an ohm reading you'll find that the ohms do not correlate with the temperature that's displayed. I just trouble shot one and I'm getting 51.2 ohms which equates to 10 - 20 degrees Fahrenheit which is obviously not what is being displayed because it's 126 which is a common number that's displayed when a thermistor is not reading properly
5/3/2017 10:28:09 AM • Pentair MASTER... • Answered on May 03, 2017
2answers
Flow issues through MasterTemp 400
are there shut off vavles you may have overlooked after the the filterpump?
5/25/2015 10:04:25 PM • Pentair MASTER... • Answered on May 25, 2015
2answers
How do i replace the stack flu sensor?
Remove the side panels, now youre able to remove the wing nuts securing the top, now you can see all of the wires and components. Depending on the age of your heater, youll have a stack flu switch or stack flu sensor. To find the sensor, start at the exhaust vent and follow that black exhaust pipe till you get to the head of a bolt with 2 wires sticking out. Remove the wire connections, and unscrew old part, install the new sensor, you can not wire this up incorrectly, so its not important to mark the wires.
4/27/2015 4:19:10 PM • Pentair MASTER... • Answered on Apr 27, 2015
No readout on on board. No on light when pushing on pool button
No power being sensed, check main. if power to heater, check for voltage at transformer: both primary and secondary. if primary reads whatever voltage you supplying heater, then check secondary, if 0, bad transformer. If 24-28 volts, then circuitry is bad, further diagnostics required.
4/18/2015 2:54:43 AM • Pentair MASTER... • Answered on Apr 18, 2015
Pentair MASTER TEMP HEATER 400 000 BTU NG LOW NOX HD EXCHANGER Logo
59 questions posted
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
View Most Popular
Pentair Pool & Spa
  • Pentair Pool & Spa
Most Popular Question
just purchased master temp 400 pool
  • Pool & Spa
