20 Most Recent
Pride Mobility Products Celebrity X - 3 Wheel Scooter - Candy Apple Red Questions & Answers
Need manual for celebrity x
Go to cheapest-scooters.co.uk Then click on photo of celebrity x sport mobility scooter.Then scroll down page and click link to download owners manual. Hope this was helpful?
How do I remove the seat on my Pride Mobility
Please take care going out the following action: sounds to me like it seized in the tube, with care, lay the scooter at a 45 degree angle, moving your self so you can see where the tube connects to the seat base now stray some WD40 or anything that works on rust etc and leave for a hour , now try wiggle the seat while releasing the seat move catchRegards GeWiz....
Batteries are fully charged. Scooter goes at full
Based on your description you have a bad throttle potentiometer or speed potentiometer. Remove the covers of the front console and check the resistance throughout the range of both pots at the connector. It should be even throughout the range with no dead spots. The newer CTE throttle pot is more reliable than the older model Celebrity scooter with the 5K ohm potentiometer. I usually replace the throttle and speed pots as a pair since they are connected electrically in the console.
Load test the batteries while you are driving. Using your voltmeter that is still connected under the rear cover while you are driving, check to see if you get a voltage drop of more than 1 volt. Static testing of batteries only tells you that there is a full charge. It does not give you an indication of how the batteries perform under load.
If you have clean brushes, you can still have a large amount of conductive brush dust in the motor and armature. Blow out the dust with compressed air. Check the motor and brake with you meter. The motor coil resistance should be less than 1.5 ohms and the brake should read between 40 to 60 ohms. Hope this helps.
Pride Celibrity 3 wheel electric scooter. The motor isn't working
the click is the electric brakes releasing , most likly the problem you are having is the brushes in the motor may be shot cheap easy fix on each side of the motor there should be what looks like a flat head screw those are the brush covers remove them and check them replace as need , otherwise the motor may be shot
Replace batteries
Hi. To remove the batteries, it is neccessary to remove the seat first. Turn the seat a bit and then lift it straight up. Next remove the cover under the seat, it will probably be held on with velcro. Under the cover you will see the batteries. They will be held in place by fabric straps, which you will have to loosen. Make sure that the machine is turned off, unplub the batteries and remove them.
You will be the best judge of the condition of your batteries.
Can you travel as far as you used to, without the battery gauge falling further than it used to?
It is important to recharge your batteries after each trip, and to charge them overnight at least.If you haven't used the machine for a few weeks, give it a charge overnight.
Some chargers can be left on for weeks at a time, and some chargers should only be used overnight only. The reason for this is that some chargers, such as the Invacare 8 amp charger, will drop down to a float charge after charging the batteries. Most of the smaller 4 amp chargers do not drop down to a float charge, but maintain the full voltage untill they are turned of.
Good luck. Neil.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
