20 Most Recent
Pride Mobility Products Pride Mobility Victory 4-Wheel Electric Scooter Questions & Answers
My victory scooter will not go foward
if the throttle pot feels okay that is what the lever is attached to ? is it loose ? if it goes in reserve okay i would say it's the throttle pot, i can get you one of these if required.
What is a tiller ?
the tiller is the steering shaft, the long portion from the handlebars down to the the tiller is the steering shaft that is located from the handlebars downto the wheels, it can usually be folded down to transport a scooter in a vehicle
Pride vicyory viper mobility scooter. no power no
about the only thing I can suggest is to make sure you have power out of the batteries going to the system. If you have a charger port located on the tiller take a digital volt meter and set it to 200 vdc and plug the leads into the two outter holes of the charger port with a full charge you should read 25-27 volts. If you don't have a reading at the port then there is a problem with the power getting to the tiller. It could be a bad cable Pride is notorious for developing problems in the cable going to the tiller. I would suggest you find a repair service to check the scooter for you. Maybe your provider (where you got the scooter) has a tech that can check it for you. I'm sorry I can't give you a definite answer but there are so many things that can affect a scooter: bad throttle, bad speed pot , bad cable, bad connections, bad batteries that its difficult to give you one answer that will fix your probelm Hope this helps you
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
