20 Most Recent Black & Decker 750w Power Inverter Questions & Answers
2answers
I think i blew the fuse in my inverter by putting
http://servicenet.blackanddecker.com/Parts/Search?searchedNumber=750%20Watt%20Power%20Inverter
There are around 8 models of the 750 watt inverter. The above web link takes you to the Black and Decker site where you can input your exact model number and then you can download the instruction manual which has the details for how to change the fuse.
3/1/2015 4:17:55 AM • Black & Decker... • Answered on Mar 01, 2015
0answers
I blew a fuse. How do i get at it? I cant even see
Hi, you need to remove the cover of the unit and inspect the three 40 amp fuses inside. They are the blade type similar to the ones found in automobiles. Hope this helps
11/17/2010 10:13:30 AM • Black & Decker... • Answered on Nov 17, 2010
Reversed cables and blew a fuse. how do i get it out???
I think the needle nose pliers may be best. insted of grabbing by the thin sides, grab it the wide way and gently rock it back and forth. I think this is like a 35 amp fuse, so the holder has to be very tight to keep a good connection. I have one of these, and for two days I thought it was bad untill I pressed the red on button.
7/26/2010 5:21:05 AM • Black & Decker... • Answered on Jul 26, 2010
Inverter not working
Inverter is charging battery but if I switch on load button , It starts making noise loudly. can you suggest solution
7/1/2010 1:25:16 PM • Black & Decker... • Answered on Jul 01, 2010
How do I replace the fuses in a 750 watt black and
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
7/5/2009 9:26:14 PM • Black & Decker... • Answered on Jul 05, 2009
Connection to car battery
The answer is yes...BUT make sure the polarity is correct and the inverter turned off when you make the connection
5/7/2009 1:21:35 AM • Black & Decker... • Answered on May 07, 2009
2answers
Fan doesn't run on my power inverter
I can't answer your question but I strongly suggest you urgently contact the manufacturer or dealer in order to clarify this most important point as a 3kw inverter isn't cheap and shouldn't need replacing very often.
8/31/2017 11:54:57 AM • Black & Decker... • Answered on Aug 31, 2017
Husky jump-start ac/dc adapter to charge Husky jump-start 400 amp
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
12/1/2014 11:55:16 PM • Black & Decker... • Answered on Dec 01, 2014
The inverter turns on and fans run for
well the yellow light indicates a fault, the 5 volt USB is independent of the invert-er function, you kneed your unit serviced or possibly you have a low voltage cutout or high voltage protect ,check you manual for led fault indicator descriptions, battery voltages should be between 10.9 volts and 13.8 volts this can cause a fault if outside this range.best regards Falco
11/5/2013 7:02:01 AM • Black & Decker... • Answered on Nov 05, 2013
I bought a new Black and Decker 200 watt power
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
8/23/2010 3:42:24 PM • Black & Decker... • Answered on Aug 23, 2010
Black & Decker 750w Power Inverter Logo
13 questions posted
Top Black & Decker Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Black & Decker Electronics - Others
Most Popular Question
reversed cables blew fuse get out
  • Electronics - Others
