20 Most Recent Vector VEC010S Jump Start System 300 Amp starting power Questions & Answers
Yesterday I tried to jump
It takes time to charge the battery. Maybe you have an old battery, replace it.
9/6/2017 1:53:21 AM • Vector VEC010S... • Answered on Sep 06, 2017
2answers
I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer I would like a replac
I know how you feel because I had the same problem with mine until I read about the procedure. Most of those Jump start chargers unfortunately require that you charge them when you buy it and then maintain the charge at least once a month. There is usually a light on the charger to indicate that the charger is fully charged.
3/9/2016 2:28:33 AM • Vector VEC010S... • Answered on Mar 09, 2016
Where does one find a replacement battery for a
Go to battery spec.com look up battery jump start then click on vector jump starter battery is a TR9-12A
12/8/2015 4:40:42 AM • Vector VEC010S... • Answered on Dec 08, 2015
Recharging the Vector Start-It compact elite Jump Starter 12 volt
yeah from what im to understand... you charge it overnight, and yes another way to use it (and possibly better way) is connecting to the battery directly..... it should work on your van fine i think, its worth a shot, hope this helps :)
3/10/2014 11:44:05 PM • Vector VEC010S... • Answered on Mar 10, 2014
The on off switch is
There may be just a wire loose, Also check radio shack for a rocker switch
8/22/2011 3:53:24 PM • Vector VEC010S... • Answered on Aug 22, 2011
0answers
I want to change batteries in my 03 Crown Vic and
This actually quite a good trick to provide an appropriate (eg. charged) 'alternate' DC power source to maintain the minimum voltage and current to hold the computer, radio and alarm setting for your car while swapping your car battery (I have myself used 2 small 9 Volts batteries in series via alligators clips for this purpose): just make sure that it is connected on the correct side of the cables where voltage and current will be maintained after the main car battery is disconnected!
Hope it works for you and have fun!
4/25/2010 10:42:21 AM • Vector VEC010S... • Answered on Apr 25, 2010
I am looking for the 120 volt charger cord for the
I got this off amazon.com i think it is the correct one, also went on black&decker to find the user manual, attached links.... the batteries on these things don't last long though good luck.
http://www.amazon.com/gp/product/B002V6VIZW/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000B794PY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1NDZ7E054VC89M01SQ29
http://www.blackanddecker.com//customercenter/faq.aspx
1/10/2010 4:52:03 PM • Vector VEC010S... • Answered on Jan 10, 2010
My vector start-it elite jump starter is not
Hi Ydja,
The batteries on these jump boxes don't last very long. I've been through three of them. Never again.
Now I just carry an extra battery. It's more powerful and has laste longer than the three jump boxes put together.
Best regards
Mike
12/12/2009 6:09:42 PM • Vector VEC010S... • Answered on Dec 12, 2009
3answers
Everything works but the jumper cables
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
11/10/2009 7:03:10 PM • Vector VEC010S... • Answered on Nov 10, 2009
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Vector VEC010S Jump Start System 300 Amp starting power Logo
Popular Tags
27 questions posted
Top Vector Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you a Vector Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Vector Electrical Supplies
Most Popular Question
vector 300 amps will not charge or hold
  • Electrical Supplies
