20 Most Recent Korg PA800 61-Key Professional Arranger Keyboard with Speakers Questions & Answers
You need to make sure the device memory is not full, that is the most likely problem here.
Korg PA800... | Answered on Sep 07, 2016
After a little research I discovered that Behringer has had problems in the past with there power supplys so I replaced the faulty one and so far the problem has been solved. Our local power company has been sending to much power to our church building and that is what caused to old power supply to burn out. We are still trying to get them to take care of their issues.
Audio Players &... | Answered 7 hours ago
GO AWAY AND STAY THERE WE DO NOT MAKE CLOCKS OR ANYTHING ELSE
Audio Players &... | Answered Yesterday
Check the belt- if it is a belt drive turntable.
Audio Players &... | Answered 2 days ago
Check your Ariel connections for corrosion (clean them all up)
Have you relocated the unit?
Have you placed/relocated any other electrical devises near it recently??
Hello Dilum, make a test to control the sound level of the speakers connected to your harman kardon, you must press for more than two seconds the test key that is on the front panel, in the set of keys at the bottom
With the Test, you will be able to check the volume of each speaker individually, this is explained in the user manual on page 4 Item 9
If with the test, the level is fine, then you would have some problem in the recording or the program you are listening to
I hope I can solve the problem
Greetings Franco Dosil
Hola Dilum, haga una prueba para controlar el nivel se sonido de los parlantes conectados a su Harman Kardon, debe presionar por mas de dos segundos la tecla test que se encuentra en el panel frontal, en el conjunto de llaves en la parte inferior
Con el Test, va a poder chequear el volumen de cada parlante en forma individual, esto esta explicado en el manual de usuario en la pagina 4 Item 9
Si con el test, el nivel esta bien, entonces tendria algun problema en la grabacion o el programa que este escuchando
Espero pueda resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf/7/658/65714-harmankardon/avr20ii.pdf?3e1777e124b0c9a1878f4d39601e577d&take=binary
An internal fuse may have opened.
please give more info of your problem. on what source are you not having sound? in all sources like your tuner, auxilary, tape CD etc...?
Korg PA800 61-Key Professional Arranger Keyboard with Speakers Logo
4 questions posted
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Korg Audio Players & Recorders
Most Popular Question
reset factory sitting just not load
  • Audio Players & Recorders
