20 Most Recent Rio Nike PSC Communicate (14 Channels) 2-Way Radio Questions & Answers
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Rio Nike PSC... | Answered on Jan 30, 2014
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Rio Nike PSC... | Answered on Mar 15, 2011
The Nike PSC radios operate in the FRS (Family Radio Service) band, in the 462 and 467 MHz ranges. They are low-power radios and no license in required to operate them.
Rio Nike PSC... | Answered on Feb 12, 2011
https://www.cardosystems.com/support/g9x get help from above link, it is user guide and some problem and their solutions.
Radio... | Answered Yesterday
https://www.test-guide.com/free-gre-practice-tests.html
See this site, and if you want to appear you can do practice for examination.
Its better you change the speaker if you need more audio otherwise its ok, at least your hearing the sound.
Raymarine Ray55 Manuals Down Load user manual and reset MMSI according instructions.
Radio... | Answered 2 days ago
You have the modulation problem. If you have hand free you connect it and try to send message, if other unit hear you then it mean your microphone has faulty and replace the microphone, the fault is in mic or other circuit from mic input to modulation device which may be any transistor , capacitor or any resistance faulty. Consult with any Radio Service Shop.
You check your radio with other radio very near. If radio is hearing your transmission then it mean that your Radio Power Module not working if very near radio not listening you then your preamplifier and Power amplifier is not working, it mean your Radio Transmitter faulty, only Receiver is working, you consult with any Radio Service shop. One other thing if you have software also check Tx/Rx frequency it must be same for simplex operation.
https://www.gme.net.au/media/2444484/tx3350_im_web.pdf
Download user manual from above link and read page 12 for scanning.
Rio Nike PSC Communicate (14 Channels) 2-Way Radio Logo
5 questions posted
Top Rio Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Rio Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Rio Radio Communications
Most Popular Question
change frequency rkio nike two way radio
  • Radio Communications
