20 Most Recent
Kohler Model 15160L: Coralais® Single-control Pullout Spray ADA Kitchen Si Questions & Answers
How do I access the aerator on the the subject
You have an aerator that requires a key because it is recessed into the faucet. You can acquire one by calling 1-800-4-KOHLER as all Kohler faucets come with a lifetime warranty. You can even ask about getting a new aerator. Technically you can get it out by using two small flathead screwdrivers and turning them counterclockwise, but I would advice using the key because you can either scratch the faucet or injure yourself.
K-15160 Kohler faucet switch to change single
they get gunked up with grease and junk, and or mineral deposits from well water---unscrew the aerator housing(underside of rounded pullout part) inspect and clean all part making sure there are no cracks in plastic junk used today...also noting correct placement of parts
Misaligned lever on Kohler kitchen faucet
There are two possible things to look at.
Because you say "misaligned" and "frozen" it could be the handle is not set to the correct position.
There is a set screw holding the handle in place. It is a hex key I believe on that tap. Loosen the set screw and lift the handle off. move to the correct neutral position and set the screw.
If this does not do it and you are getting nothing but hot. The ceramic ball and washers could be stuck or broken. While the handle is off remove and inspect them. They should move freely in the socket. Replace or repair if necessary. Just take them to a plumbing store they are common parts.
Hope this helps. Please rate the answer if it helped you.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
