20 Most Recent Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Questions & Answers
You are going to have to try to push it through the stuck point. It is clogged without a doubt. Could be a piece of silverware in there. Use a flashlight and take a look down in the hole. Do not stick your hand in there but you can use a pliers or something to dislodge it.
Buck... | Answered on May 16, 2016
Are you sure the blade is turning? If its not, there is a hole in the bottom you can fit an allen wrench into to turn the motor and break it free again.
Buck... | Answered on Sep 03, 2015
It is likely that the drain is clogged. It will have to be cleaned.
Buck... | Answered on Nov 27, 2014
You have a clog where the drain pipe leaves the garbage disposal that isn't draining fast enough or not at all. Or it could be a clog in the dishwasher drain hose where it connects onto the disposal.
Buck... | Answered on Oct 23, 2014
First unplug the disposal from the electrical outlet. Do not just shut the switch to the off position.
You will need to drain the water sitting in the trap so place a container under the trap to catch the water.
Loosen the collar on the disposal ( use a small hammer and screwdriver)
Remove the old gasket on the top of the disposal and replace with the new gasket.
Place a little plumber's silicon on the gasket and reinstall the disposal. ( it might be a little difficult due to the new gasket)
Check for leaks and then plug the disposal back into the outlet
Buck... | Answered on Sep 23, 2014
Full user manual for this here. Cleaning it etc.
Don't think you would destroy the seal if you are careful. Sure you could get a spare if you did from their answerline at top of manual.
http://www.scribd.com/doc/9725184/Badger-5-garbage-disposal-user-manual
Buck... | Answered on Sep 14, 2014
disposal unit may need tightening into the sink. May have come loose from vibration. OR the disposal has gone bad and old and needs replacement.
Buck... | Answered on Sep 01, 2014
Motor jammed.
Find a reset switch on the bottom.
Buck... | Answered on Jul 31, 2014
It would appear there is a blockage (a clog) in the disposal. You might try "FIRST" unplugging the disposal from under the sink. Put a piece of masking tape over the switch to secure it in the "OFF" position. Then remove the black rubber strainer from sink leading down into the disposal. (just pull it out by hand) Clean out all debris by hand. Put the removed debris in the trash can. Run hot water down into the disposal assuring it to drain properly. Do not put items into the disposal which cannot be ground up easily such as potato peelings and meat products.
Buck... | Answered on Jul 19, 2014
that is a project I wouldn't reccomend. besides the "blades" are not really changable. The blades are a piece of metal cut at an angle and when they spin they grind the food by rubbing against a series of holes in the base.
if the disposal is not grinding the food, then its time to replace the disposal.
Buck... | Answered on Jul 31, 2013
Copy following links to identify problem:
http://waterheatertimer.org/images/Knock-out-250.jpg
http://waterheatertimer.org/How-to-repair-and-install-Garbage-disposal.html#install
Add comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Buck... | Answered on Apr 08, 2013
Copy following link for troubleshoot walk-thru:
Check that unit is receiving 80% rated voltage
Humming sound means start capacitor has gone bad.
Replace disposal.
Buck... | Answered on Mar 24, 2013
1) Probably replace disposal, unless unit is still under warranty.
2) Add comment and say what you discover
Buck... | Answered on Feb 06, 2013
Use vacuum cleaner down into disposal.
Copy following link for general troubleshoot tips:
Buck... | Answered on Dec 28, 2012
Buck In-Sink-Erator BADGER 5XP BADGERVEXP Garbage Disposal Garbage Disposal - Bl Logo
79 questions posted
Top Buck Home Experts
Donni Steen
Gene Haynes
Steve Allison
Steve Allison
Are you a Buck Home Expert? Answer questions, earn points and help others
View Most Popular
Buck Home
  • Buck Home
Most Popular Question
replace gasket garbage disposal
  • Home
