20 Most Recent Kohler KOHGP51487 Authorized Original Replacement Part Tank Gasket For All Questions & Answers
Shuit off water and remove the three bolts under the bowl in back lift off tank and remove gasket by pulling it off the bolts install new bolts inside tank install the white washers on the bolts then install them in tank and putr gasket on bottom of the tank and reinstall the tank to bowl and tighten down nuts be carefull not to over tighten bolts cause the bolts will snap the porecelain ears on the toilet.
Kohler... | Answered on Nov 30, 2014
This question is in the wrong area.
Kohler... | Answered on Jan 29, 2013
Turn off the water to the fixture.
Flush the toilet and hold the handle down to let as much water out of the tank as possible.
Sponge the rest of the water out so the tank is dry.
Remove or undo the water supply tube from the fill valve.
Remove the three bolts holding the tank to the bowl and remove the tank.
Replace the old seal with the new one and reverse the whole process.
You should be good to go.
Good luck.
Kohler... | Answered on Mar 06, 2011
I usually use a small bead of silicon when I install Gaskets their for I am sure not to overtighten..........Hope this helps.
Kohler... | Answered on Sep 04, 2010
Inside the tank it has a gasket from the stand pipe to the bottom of the tank. The stand pipe threads go through the tank and a plastic nut holds it to the tank. Then a gasket goes on the nut and threads to make a seal between the tank and bowl. I have included this picture that has the above look. I hope this will be of some help for you.
Kohler... | Answered on Sep 02, 2010
can't tell you the part number but it's not to complicated. first shut off the water supply, then flush the toilet to get the water out of the tank, then remove the water supply line, then unbolt the tank from the bowl and replace the gasket. be carefull when tightening the tank back up, you want to do it evenly and only untill the tank is solid. or you can crack the tank
Kohler... | Answered on Sep 20, 2009
never have used a torque wrench to install toilet tanks. Put gasket on tank and insert bolts with rubbers washers through gasket and set tank on bowl in a level and straight postion and start nuts tightening them evenly until tank starts to snug to bowl. Hand tight is usually sufficient, you will see the rubber gasket and washers will compress to bowl and tank forming a seal (EVENLY) and tank will be firm to bowl. DO NOT superman torque these nuts! Compare the torque to finger strength on a wing nut. Hope this helps ,"if I understood the question."
Kohler... | Answered on Jul 07, 2009
Anything is possible, you could look to see if the fuel tank appears newer then the rest of the under body, however a new fuel tank is not such a bad thing, if it were installed properly...
Kohler... | Answered on Mar 11, 2009
First, identify the style of your quick connect hose.
See the steps on this Kohler Fawcet Link for disconnecting your pull-out kitchen faucet quick connect hose. Follow this link: https://support.kohler.com/hc/en-us/articles/360001798834-Disconnect-Quick-Connect-Pull-Out-Kitchen-Faucet-Hoses
Make sure the water valves are closed and the water pressure is relieved before attempting to service your kitchen taps.
Kohler Home | Answered 2 days ago
The brand of toilet doesn't matter. You need a product that cuts calcium and lime. It may take some soaking and scrubbing. Once you get it clean, use the product regularly.
CLR makes a line of products:
https://clrbrands.com/en-US/Products/CLR-Household/CLR-Calcium-Lime-Rust-Remover
Kohler Home | Answered on May 10, 2019
I don't know this specific tub, but here's the pictoral. The button (90105) should come out of its base, held by friction of O ring. This should allow you to disconnect the pressure line. If you are looking to replace the complete assembly, likely you will need a basin wrench to reach nut (65157).
kohler1-ggmuzyqdnvlyrlfigj0gxfoh-4-0.png Here are links to Kohler, specific to this tub.
https://www.us.kohler.com/us/catalog/svg_viewer.jsp?productId=415928&diagram=3 https://www.us.kohler.com/webassets/kpna/catalog/pdf/en/1010564_5.pdf
Kohler Home | Answered on Mar 18, 2019
you have kids??? theres probably something large in the trap
Kohler Home | Answered on Mar 10, 2019
Kohler KOHGP51487  Authorized Original Replacement Part Tank Gasket For All Logo
Popular Tags
14 questions posted
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
gas tank 2001 camry loose filler tube
  • Home
