20 Most Recent
Neptune FB1635 Catania Toilet Questions & Answers
It leaks in the bowl
Hi rvscharman...
Your "Flapper Valve" is leaking water by....Replace it.
The flapper valve is the one that the handle is attached to....normally attached to the overflow pipe.
Please take time to rate me
I'm trying to install my Neptune Catania toilet
If the toilet does not sit fully on the floor then it will need to be shimmed. Use plastic, fiberglass or composite shims to level the toilet. Wood shims will rot. Caulk around the front and sides of the toilet to hide the shims. Do not caulk around the back as if the toilet leaks you will not be able to tell if it is fully caulked. Epoxying the flange will work however you will want to check with local building codes to ensure this is compliant.
My toilet seat broke, where do i geta replacement?
Unless there is something unusual about the seat you should be able to buy a standard replacement seat at Home Depot or Lowes. They come in round and elongated and there are a number of styles available. Measure the distance between the center of the mounting bolt holes and match with the display to see if they will work.
Jets not working
Check your breaker in the breaker box. Is this an air tub or a water tub?
5/1/2014 4:28:38 PM •
Neptune Home
Answered
on May 01, 2014
Diagram of Neptune London toilet
That is easy one and it can be found on web at: https://www.google.com/search?q=diagram+of+Neptune+London+toilet&rlz=1C1CHFX_enUS585US585&tbm=isch&imgil=RTkcifF8SZTgWM%253A%253Bhttps%253A%252F%252Fencrypted-tbn0.gstatic.com%252Fimages%253Fq%253Dtbn%253AANd9GcSAazJRK0LrrdOc17FHxtBLnpucOCZVAke-NkUfD0OcBUVd3zXD%253B508%253B554%253BHrqiGCSatA0tNM%253Bhttp%25253A%25252F%25252Fwww.heatandplumb.com%25252Facatalog%25252Fprestige-klpk015-neptune-cloakroom-suite.html&source=iu&usg=__skXhP7gi2d0BZEUMGsJGjQnkwnw%3D&sa=X&ei=Yo1cU9KeBoaq8AHR64CYDg&ved=0CC8Q9QEwAg#facrc=_&imgdii=_&imgrc=dFSWP0tAfgLWKM%253A%3ByG16YVrT12A-vM%3Bhttp%253A%252F%252Fwww.heatandplumb.com%252Fimages%252Fk-series%252Fdimensions_product_KLPK011.jpg%3Bhttp%253A%252F%252Fwww.heatandplumb.com%252Facatalog%252Fprestige-klpk011-neptune-close-coupled-toilet.html%3B516%3B242
4/27/2014 4:57:17 AM •
Neptune Home
Answered
on Apr 27, 2014
The handle on my sink faucet broke off
turn the shut off valve under neith the sink counter clock wise. this shuts off the water. Then take the stem off. This is what the handle fits on to. Then write down any words on any part of the faucet. Then Take the broken handle and stem which usually unscrews and what you wrote down( the brand of faucet to home depot) and ask the plumbing specialist. Go any where from 10am till400pm thats the best time to get a plumbing specialist
9/5/2013 4:37:28 PM •
Neptune Home
Answered
on Sep 05, 2013
Neptune whirlpool blower goes on automatically
I heard about the Neptune Whirlpool blower that it is new and best bath tub which is working automatically. It comes White, Biscuit or Bone colors. I am wondering to purchase it for my bathroom. But I don't know its original price. So please help me ?
8/16/2013 9:16:16 AM •
Neptune Home
Answered
on Aug 16, 2013
Keeps going from boiling hot to cold
At a guess either the shower head has become clogged/calcified or the piping inside the shower has become so.This means that water stays in the system too long, becomes over heated and the failsafe cut off activates.Try cleaning or replacing the shower head.
1/30/2012 3:49:33 PM •
Neptune Home
Answered
on Jan 30, 2012
