20 Most Recent Nikon One Touch Zoom 90S 35mm Point and Shoot Camera Questions & Answers
2answers
WILL CAMERA WINED WHEN BATTERY DEAD
No. The winder is electric, and needs juice from the battery.
10/21/2016 6:55:33 PM • Nikon One Touch... • Answered on Oct 21, 2016
Where to buy nikon one touch 90s film?
35mm film should still be available at any camera store. Many drugstores and supermarkets also stock film, though not as wide a selection.
10/25/2014 3:48:14 PM • Nikon One Touch... • Answered on Oct 25, 2014
Video shot with nikon one onto card will not play on computer
To play all the different media files cameras can make your computer needs software. If you have installed Nikon ViewNX(2) on your PC, that program should be able to play the Nikon video format. You also can use that software to import the Photos and Videos from the camera to the computer.
12/2/2013 9:05:21 PM • Nikon One Touch... • Answered on Dec 02, 2013
2answers
What is macro used for
It's used for extreme close up shots. The setting allows the autofocus to focus closer than it normally can, but may prevent it from focussing on distant objects.
9/20/2010 5:13:28 PM • Nikon One Touch... • Answered on Sep 20, 2010
Quartz Display "date" does not work
Hello Janet,
Are you the Janet Schask who asked about the Walker mine
in 2002? I am looking for James Carlile current E-mail address.
Thanks,
**** Vandermeyden, [email protected]
Hillsborough, CA
9/17/2010 8:33:11 PM • Nikon One Touch... • Answered on Sep 17, 2010
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
2/26/2010 9:07:53 AM • Nikon One Touch... • Answered on Feb 26, 2010
2answers
Nikon One Touch Zoom 90 AF quartz date
I have the manual. Email me if you still need it and I could photocopy it.
2/1/2010 2:54:29 PM • Nikon One Touch... • Answered on Feb 01, 2010
Nikon one touch zoom 90 camera
I bought this camera at Value Village for $1.99. It came up with an E. I assumed this was an E for empty. I loaded a film and it is fine. [email protected]
8/20/2008 1:03:12 PM • Nikon One Touch... • Answered on Aug 20, 2008
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
3/27/2024 3:34:09 PM • Nikon Cameras • Answered on Mar 27, 2024
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full. r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining. If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
1/28/2024 3:26:09 PM • Nikon Cameras • Answered on Jan 28, 2024
I'm using a Nikon D3100 with a kit lens & my 55-200mm lens. And most of the time I encounter a problem every time I press the shutter button due to r07?
  • The "r07" message on a Nikon camera typically indicates the number of available shots in the camera buffer. It's not an error but rather an informational message. The number "r07" means that there are seven shots available in the camera buffer before it fills up. This is a normal part of the camera's operation and doesn't necessarily indicate a problem. It's more noticeable when you're shooting in continuous or burst mode. If you experience issues beyond this, it's advisable to check your camera settings and consult the camera manual. https://caranddriver.com/
1/26/2024 11:54:11 AM • Nikon Cameras • Answered on Jan 26, 2024
Hey guys, I've got an OLympia Dl000a analog camera with a 50mm lens. can I remove the lens from body & attach it to my nikon d 3200?
it will not fit, but rather than ask why did you not just try it.
1/24/2024 4:08:45 PM • Nikon Cameras • Answered on Jan 24, 2024
Nikon Coolpix s8000 not turning on after charging with provided cords. I've tried charging with both the computer via USB and wall charger.
Try replacing Battery. For further rectification, see page 151 of user manual error messages. S8000_ENnoprint.pdf (nikon-cdn.com)
1/1/2024 2:33:57 PM • Nikon Cameras • Answered on Jan 01, 2024
Nikon 910 Speedlight Flash, how to replace battery cover?
User's Manual
nikon-cdn.com https://cdn-10.nikon-cdn.com > SB-910_EN PDF The SB-910 is a high-performance Speedlight compatible with Nikon Creative. Lighting System (CLS) with a guide number of 34/48 (ISO 100/200, m). (111.5/157.5, ... 136 pages
SB-910 - Nikon ' Download Center
Nikon ' Download Center https://downloadcenter.nikonimglib.com > products Download product manuals. Download product manuals. Title Language Size. User's Manual English 3.53 MB Download. Manual Download Agreement. ..
12/20/2023 7:35:29 PM • Nikon Cameras • Answered on Dec 20, 2023
Nikon Coolpix S570 won't focus in any mode on any object (near or far). No warranty. Is there a way to fix myself?
No unfortunately not. Camera repairs are very complex and require special tools. They are also repaired in a clean room with filtered air by men and women of full cover, coveralls. No fluff or specs on the sensors. Help here including a good answer on JustAnswer. https://www.google.com/search?q=Nikon+Coolpix+S570+won%27t+focus+in+any+mode+on+any+object ..
11/14/2023 6:33:17 PM • Nikon Cameras • Answered on Nov 14, 2023
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue: Remove the battery from your camera. Fully charge the battery using the Nikon D80 battery charger. Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover . If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
10/28/2023 6:35:06 AM • Nikon Cameras • Answered on Oct 28, 2023
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f.... Most of the time, this F Error message is limited to Nikon DLSR cameras. This particular error message appears when the camera is not able to communicate with the lens. To fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place. If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center. I'm not a camera buff but I thought I'd pass this on. other sites too.... https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web Best to you.
8/14/2023 12:00:03 AM • Nikon Cameras • Answered on Aug 14, 2023
Nikon One Touch Zoom 90S 35mm Point and Shoot Camera Logo
Popular Tags
17 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
Nikon Cameras
  • Nikon Cameras
Most Popular Question
nikon one touch zoom 90 af quartz date
  • Cameras
