20 Most Recent
VeriFone Inc 999-Bpp-00340 Mx850 Buyer Protection 3Yr Mx8Xx Int Sale Questions & Answers
How to unlock the keypad on a VeriFone Terminal
if you are getting a keypad locked message.
from the main screen press the number 8 and then 1 alpha alpha 66831 enter then NO
this will unlock the keypad, which got locked by pressing the number 8.
How to thread paper
no need to thread paper when replacing, set in cradle, close the door, making sure the paper has about 3 inches of a tail which you will pull towards you and shut the door, tear off excess no feeding needed.
How do I feed new paper
no need to feed paper simply pull about 3 inches of extra paper from roll, after placing paper in cradle, close the door on the extra paper and tear, this is all no feeding needed
Getting server not allowed on VX510
that means the server number you entered is not valid, make sure you are using correct server number, or if you are not using server numbers make sure your device is not asking for a server number before transactions can be performed.
Vx 570 auto settlementIf I manually settle my VeriFone credit card terminal in the morning, why doesn't it auto settle at the scheduled time that night?
the terminal is set internally to settle each day on it's own. you can have this turned off if you don't like the feature.
if you select the 0 key or press enter if 0 does not take you to configuration menu. enter your default password or 1 alpha alpha ( key is above the 2)66831 enter, then select the purple more key until you see merchant id.
select merchant id. then press next until you see auto settle time, press select when you see auto settle time. remove the time using backspace key, select exit and save changes red x to main screen. the auto settle should be removed now. but if you do a download you will lose this information so it is best to contact your processor to have your file updated.
Tcp error 10050042
TCP error means you are not connecting to internet, reset your modem and try again make sure you can get to yahoo.com or similar site, if you can then press star key above red x go to tools and then ping test.
then toruble shot and then repair key
No master key
theres a default passkey just look up the specific model hand book
Technical support questions
That would depend entirely on the software you are using on the pc to talk to them. There is no reason it wouldnt work but your software would need to support it and I expect that would be a fairly rare requirement.
