20 Most Recent
Cretors Goldrush Popcorn Maker Questions & Answers
My popcorn machine won't heat up
No heat at all most commonly used is just a burned wife connection in the kettle . I find that a lot of the time. To repair it you should use high temp nickel ring terminals. Standard ones won't last l long like these do. It might be time for a while new KETTLE wire set. Find a dealer in your area . They should help you determine what to do.
Popcorn takes too long to pop
On the Gold r unjust like the bigger units the smaller light that comes on when you turn the kettle switching tells you the thermostat is closed and it's heating. Monitor the popping cycle and see when it goes out . A common problem would be it's shutting off to soon so it's not getting enough heat to pop in the correct amount of time. If that's the case replace it. That one is not made to be ajusted.
http://www.cretors.com/dealer
NEED GLASS DOORS
If you have a local hardware store who can cut them straight that's the simplest.
Why won't the kettle heat up to pop
The heating element needs to be checked to see if it has power and if it has burned out. To do this, you need a meter that checks voltage and resistance. To test it, locate the connections to the heating element and with the machine unplugged test the heating coil with the meter set to measure resistance. It should not be infinite. IF it is then the coil is burned out.
Kettle motor is out
The motor for a Gold Rush 6oz popper is #2429-A. It is available from any Cretors Distributor with a service dept. I don't think you can buy Cretors parts online anywhere. http://www.cretors.com/dealers.asp?i=16
My popcorn machine wont heat up
First, if you have another cord like this one (for example, a coffee pot cord) plug it into the popper and see if it works.
If it's not the cord, it's probably a blown thermal fuse inside the unit. Could be a heating element broken as well. If you don't have appliance repair experience, I would take it to a repair shop.
