20 Most Recent
Quakehold! Bear Claw Water Heater Seismic Strap Questions & Answers
We have two Venetial glass urns attached with QH
QuakeHold is made by a company called ReadyAmerica, My dad had the same problem and called them and they told him what to do and it worked. We were more concerned about the Urn, which contained his Mothers ashes than the table and tried everything bit I just knew I was going to break it. He called and told me he got it after talking with ReadyAmerica but it has been a while and I don't remember exactly what he did, but I got their phone number for you: Toll Free 1-800-959-4053. I hope that helps. I am afraid it will leave marks on the wood though, but that can be covered with a Doilee hopefully!
Can oly get to one 2x4
If you have drywall, you can use heavy duty drywall anchors. If not, you will have to extend the straps and attach at the same point. If you don't have drywall, you can add another post anywhere if your plate is accessable.
What is error code c8 mitsubish heater
The P8 fault can mean many things when it pops up on your Mitsubishi Electric wall controller. The P8 fault is activated when the indoor coil sensor does not change the temperature for a set amount of time after the compressor is (or should be) switched on.
Rival titan floor heater coils don't turn red
Beware when working with electrical equipment. It may cause electric shock.
Check the power supply wires, connections with heating coils. If they are ok then possibly heating coils require replacement.
