20 Most Recent Price Pfister RT6-E0XC/HHL-ELBC/0X6-040 Catalina Deck Mount Whirlpool Fauce Questions & Answers
There could be debris wedge in the cartridge of the faucet. If you have tried pulling the cartridge out to see, and you are still having these issues, more than likely it is a defective cartridge; in which case it should still be under warranty. If you haven't tried this, then I would recommend doing so. Just be sure to turn water off to your faucet first.
Price Pfister... | Answered on Nov 19, 2009
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Price Pfister... | Answered on Sep 12, 2009
If you are installing a wax (doughnut) seal to connect the toilet to the main drain, then the wax ring should be big. It should 'squish' to seal correctly. You may not need it, but I've known plumbers to install two of the seals at once for extra gap-filling. Just install the seal, sit on the toilet to compress the seal into place and then install the bolts to the floor. Done!
Price Pfister... | Answered on Oct 23, 2017
you need a new tank kit, pick one up at your local Menards
Price Pfister... | Answered on Nov 19, 2014
I don't know your exact model but most faucets screen filter can be screwed off for cleaning or replacement. Remove the screen filter with a pair of pliers and a rag. Once you get it loose, you should be able to unscrew with your fingers. Put the rag around filter before putting the pliers on it to prevent gouges and deep scratches in the chrome. IF you have a dishwasher, you can clean the screen filter on top basket of dishwasher if you have one. IF the screen filter looks bad to you, just replace it. Go to any hardware store ,take the screen filter with you and get help finding the right one. Once you have a replacement, hand screw it back on as tight as you can. IF it still leaks , use the rag and pliers to tighten it just enough to stop the leak in the screw parts. Good luck.
Price Pfister... | Answered on Sep 01, 2014
Bear with me, please. Adjust the temp at the physical valve?
Interesting at the least. Never seen or heard of that. They come up with something new everyday. I'm going to follow this for my own benefit. Thank you. And good luck. - Ned
Price Pfister... | Answered on Jul 23, 2014
remove cartridge blow out water lines be careful
Price Pfister... | Answered on Feb 27, 2013
Price Pfister RT6-E0XC/HHL-ELBC/0X6-040 Catalina Deck Mount Whirlpool Fauce Logo
2 questions posted
Top Price Pfister Home Experts
Mike
mikenearman
Donni Steen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
View Most Popular
Price Pfister Home
  • Price Pfister Home
Most Popular Question
price pfister
  • Home
