20 Most Recent Rescue Pack 950 Jump Starter Questions & Answers
http://www.quickcable.com/doclib/rescue950-3000manual.pdf
pg5 of the PDF above, pg 10 of the manual
Recharging
Recharge every 30 days and after each use. Failure to do so will result in possible damage to the internal battery and result in poor performance or failure to work at all.
1. Plug the AC Charging Cord supplied into the 120 Volt-in connection on the back of the Jump Pack.
2. Plug the other end of the cord into a 110/120-volt AC outlet.
3. The Red charging LED light will glow and will remain ON during the charging process When the internal battery is completely full the Green FULL CHARGE LED light on the control panel will turn on automatically. This can take up to 72 hours depending on the condition of your internal battery. You can unplug your AC Charging Cord at this time OR leave it plugged in indefinitely as the CULâ„¢ listed internal charger is float charge equipped to maintain the internal battery
Rescue Pack 950... | Answered on Jun 06, 2019
is there something on the inside to show that the battery inside the unit is actually connected. you may have to take of ft he back and make sure the connectors to the battery are actually hooked up.
Rescue Pack 950... | Answered on Nov 17, 2015
Hi likelihood that the SLA battery is cactus, SLA's do not being fully discharged and left that way. you can buy new battery and replace!!
Rescue Pack 950... | Answered on Mar 23, 2014
check compression
Vehicle Parts &... | Answered Yesterday
if you lost all compression on all cylinders at the same time check your timing belt or timing chain. good luck .
Vehicle Parts &... | Answered on Oct 09, 2019
It is suitable for a number of vehicles, as it includes long bays for vans, and short bays for other vehicles, and with minimal alterations it is suitable for installation in any vehicle model.
It offers more storage capacity for odd sized items, and represents easy inventory control, by reducing the need for overstocking expensive items in your work vehicle.
The system is fully adjustable.
Vertical adjustments can be made to gain maximum use of your vehicle height, while horizontal adjustments can follow the contour of your van, to allow for more aisle space.
The rak-a-van system provides maximum working space and fast access to all items, and optimises productivity.
Tradesman Fitouts 4WD Sydney
Vehicle Parts &... | Answered on Sep 26, 2019
Vehicle Accessories is the leading discount store for automobile accessories. We offers you various cars and bike accessories such as tyre and wheel, replacement parts, auto spare parts , vehicle exterior and interior care services from the best brands at the most affordable rates. The company offers a wide selection of car products, including auto electronics, cleaning materials, oils and fluids.
Vehicle Accessories is an online store that offers all the latest in car parts and accessories at reasonable prices. You can find everything you need to customize your car to make it truly your own.
This Vehicle accessories shop online sells everything under the sun to deck out your car in the best way that fits your needs. If you're getting ready for the summer, you can find all the essentials like waterproof seat protectors, connectors and cables to connect your kayak or surfboard to your car, and bike racks so that you can get out and enjoy the fresh air.
Vehicle Accessories has several locations in Australia where you can buy accessories and products for your car in addition to a full range of services to keep it running at top performance.
Car Accessories Sydney
Looking for the best vehicle accessories installers from Melbourne Contact Local Mechanics Melbourne for better results.Local Mechanics are one of the premier auto repairer groups bringing together customers and their local mechanics across Australia. All mechanical services are performed by highly qualified and licensed mechanics.
Most likely the receiver antenna is defect.
Try see if it is there and is connected correctly.
Off course you have checked the transmitter battery is full!
Vehicle Parts &... | Answered on Sep 25, 2019
get some super lube. pull the cover all the way out and lube the mechinsum
Vehicle Parts &... | Answered on Sep 20, 2019
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered on Sep 15, 2019
should be on the tail of tranny left side
Vehicle Parts &... | Answered on Aug 16, 2019
You need to register with snooper to download the updates(even if previous owner has done so) or else you can ask him his user id and password
Vehicle Parts &... | Answered on Aug 14, 2019
You can use this for most of it. Most remote starts/keyless entry/alarm do the same things. Most are even colored the same way.
https://www.manualslib.com/manual/460639/Directed-Electronics-Autocommand-25523t.html
Vehicle Parts &... | Answered on Jul 11, 2019
Why you need a wrap? The new ones are wrapped mainly cos people don't like the company color and they want their ride to be unique. I believe it's the same for you. Vehicle wraps are better option; cheaper compared to repainting; easy to remove when you think you changing it.
Vehicle Parts &... | Answered on Jul 09, 2019
I would check your crankshaft sensor , also your fuel filter to make sure it is clear
Vehicle Parts &... | Answered on Jul 05, 2019
On most cars, you have to find any hidden screws in the armrests and remove those. Then if you have electric windows/door locks lift up around the base of them with a flat head screwdriver to get them to pop out and be able to unplug them. When that is done, you usually can just lift at the bottom of the door panel and you will unpop the plastic inserts as you work around the door.
What does this have to do with vehicle parts and accessories
Rescue Pack 950 Jump Starter Logo
3 questions posted
Top Quick Cable Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Quick Cable Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Quick Cable Vehicle Parts & Accessories
Most Popular Question
charge rescue 950
  • Vehicle Parts & Accessories
