20 Most Recent
Hilti 375849 TE-CX 13/16"-18" Masonry Drill Bit Questions & Answers
Hi, I am a Japanese
The SF4000a Is a cordless Drywall Gun. Even thought it has variable speeds most people run it full speed and then press and engage the chuck to run the screws in. The variable speed is used more to back out screws in reverse
Hilti switch acted 7358 ?
How is it acting? All posts need some form of explanation of the issue rather than a vague statement.
Start with 'make model (what it is)' as first three words. Then what is wrong and what you have tried. Proof read it, make sure it is properly capitalized and punctuated and then press Post. Refresh the page to see it online.
12/15/2023 6:27:15 PM •
Hilti Drills
Answered
on Dec 15, 2023
My hilti te 805 runs but no hammer action
According to the operating instructions for the Hilti TE 6-A22, if the rotary hammer is running but there is no hammering action, it could be because the rotary hammer is too cold. To fix this, bring the tip of the drill bit into contact with the working surface, switch the rotary hammer on and allow it to run. If necessary, repeat the procedure until the hammering mechanism begins to operate. Also, ensure that the function selector switch is set to "Drilling without hammering" .
If this doesn't work, you may need to take your tool to a professional repair service. You can find a list of authorized Hilti service centers on their website.
10/22/2023 2:15:17 PM •
Hilti Drills
Answered
on Oct 22, 2023
How to stop buzzing sound on hilti te 706-avr
- try to pull the trigger more back then its stand free , because i think that a dust ring insite the trigger was come loose and get inside the trigger so it will not fully come back in its normal rest position but its stands maybe a little fraction triggered , replace the switch .
8/9/2023 4:05:00 PM •
Hilti Drills
Answered
on Aug 09, 2023
Pozdrav,kako pronaci diagram shemu za hilti te 3-m
Da biste prona?li dijagram shemu za Hilti TE 3-M, preporu?ujemo da posjetite slu?benu web stranicu tvrtke Hilti i potra?ite podr?ku ili kontakte za tehni?ku podr?ku. Mo?da ?e vam biti potrebni serijski broj ili druge specifi?ne informacije o va?em ure?aju kako biste dobili odgovaraju?e informacije. Tako?er mo?ete poku?ati prona?i dijagram shemu na mre?i tra?enjem po nazivu modela i broju dijela, ili se obratiti Hilti servisu za podr?ku ako trebate dodatnu pomo?.
3/17/2023 12:37:27 AM •
Hilti Drills
Answered
on Mar 17, 2023
I have a dg150 dustless
Is it the grinder or the conditioning unit it plugs into? The conditioning unit will beep if there is insufficient power for the grinder. Contact Hilti at 800-879-8000 for service
1/14/2022 5:51:08 PM •
Hilti Drills
Answered
on Jan 14, 2022
