20 Most Recent
Electric Superwinch 12 Volt DC Winch - 8500-Lb. Capacity, Model# 1585200D Questions & Answers
Wire a winch
The 1585202 winch is capable of pulling 8500 pounds when provided adequate DC power. With no load (winding up slack the cable) the motor requires 84 amps and winds at 18 feet / second. When fully loaded (8500 pounds), the motor requires in excess of 320 amps and winds at 3.5 feet / second. That's an awfully large amount of current and it will need heavy duty power supply cables to work without overheating or melting insulation. I suspect your 1585200 is the same model with same electrical requirements, but did not include a fairlead, mounting plate, etc..Superwinch has wiring kit #2007 for front mount (5 foot cables) and #2008 for trailer mounts (25 foot cables) and can simplify the installation with other accessories as well. They're a U.S. company and can be contacted them directly:
Superwinch, LLC
359 Lake Road
Dayville, CT 06241 US
Ph: 860-928-7787
F: 860-928-1143
www.superwinch.com
1/13/2012 7:41:22 PM •
Electric...
Answered
on Jan 13, 2012
I can not get my cable out of my winch, I hear
may have ice in gears or check power connections and switch may have gone bad--radical approach take a torch low flame and warm the drum and cable not trying to get red hot just to warm up drum if ice in gears will thaw
12/10/2009 12:48:56 AM •
Electric...
Answered
on Dec 10, 2009
My electric jack hammer 1700W stopped and now nothing happens when i depress the trigger. What can i do ?
Check the brushes first, they're the easiest and most likely cause of your problems. New tools are being equipped with brushes that have non-conductive pins in them that pop out when the brushes wear down so the armature doesn't get damaged. Next, do continuity checks to see if power is geting to and through the switch. Many cords get internal breaks at or near the boot where they go into the tool from frequent bending or at he plug end from being unplugged by pulling on the cord and not he end peice. If the cord is good, check that power is going through the switch.
10/8/2012 4:31:22 PM •
Electric...
Answered
on Oct 08, 2012
What to do if 30 amp fuse keeps blowing in main breaker box
A 30 amp circuit breaker or fuse is NOT a typical size used for the protection of convenience outlets & general lighting circuits, especially in a residential setting. In fact the National Electrical Code (NEC) prohibits anything larger than a 20 amp breaker to protect a #12 copper wire and and a 15 amp breaker to protect a #14 copper wire. These are the size wires used to supply nearly all outlet and lighting loads in a residence. It's not clear to me from your question if this 30 amp breaker is a double pole type that is providing power to a second, smaller circuit breaker panel and these outlets are fed from it. This would be in line with what the NEC would allow and what I suspect is the situation. I'm only going to get into this a minimal amount as more information is needed for me to be able talk intelligently about it.I would shut off the loads that are connected to the 30 amp breaker. If that is a panel, I would shut off all the circuit breakers in it, then turn onn the 30 amp breaker. If it trips, then there is a problem between the 30 amp breaker and the panel. You may have connected line cables to ground or neutral - and vice-versa. Can you please explain in as much detail as possible what is connected to the 30 amp breaker? Is it a single pole (120 volts) or double pole (240 volts) circuit? What size wires are connect to the breaker terminal(s) What type of cable is connected to it? How many wires are in the cable assembly or pipes? What is the size of wires? If they feeds a second, smaller breaker panel, where do the wires terminate - into lugs on the top or bottom of the panel or terminals of a circuit breaker? What happened or changed to cause this circuit breaker to start tripping? Is this part of a new installation - and if so, was the wiring done by an electrician? Was the work inspected?Please try to answer as many questions as possible. The more information you can provide will help me get you the best answer.
1/19/2012 10:52:23 PM •
Electric...
Answered
on Jan 19, 2012
I am trying to find out how to use a clamp
To use clamp meter, you must be able to clamp jaws around one of the two load wires (not both at once). Easy place to do this is at the unit if cover is off, find one of the wires supplying power to compessor while running and read meter (set meter to ac). You can clamp meter to one of the lines going to fan motor to determine its draw. Another place would be at the plug. Cut power to plug and pull out the receptical exposing wires (not easy because wires are stiff and if aluminum, could be brittle, could be part of the problem if receptical plug is warm). Look for signs of heating due to loose connections. Temp connect unit to receptical and clamp meter to one leg. Turn on the breaker to plug and watch meter for good while to see if draw incrases over time. Use caution when working with electricity. Good luck and think safe.
8/13/2011 2:33:59 PM •
Electric...
Answered
on Aug 13, 2011
I only have 62.2 amps in my outlets i need 120
How are you getting this measurement? From the ".2" portion I'm going to assume that you're using a digital voltmeter, which is notorious for giving flaky readings in inexperienced hands (no offense). The second question to help sort out your problem is where are you getting this measurement from? In other words... from an outlet? Across which "pins", and have you tried more than one outlet, ideally that are on two different circuit breakers? Home wiring can't give you 62.2 volts without a significant problem, probably a bad connection but that's fairly unlikely. It would be helpful to know what caused you to think there's a voltage problem in the first place, since there may be another explanation... let me know and I'll try to point you in the right direction.
7/30/2011 1:10:09 AM •
Electric...
Answered
on Jul 30, 2011
There are a few problems.
Without a more clear discription of your electrical problem , my advice to you would be to get a qualified electrician to come in and troubleshoot your home immediately . When lights begin dimming and receptacles aren't working properly , there is some serious issues that need to be addressed ASAP ! Anything could be going on from a simple breaker issue to possibly an overload on a circuit , which could lead to more serious problems ( FIRE ) .
2/17/2011 4:50:46 PM •
Electric...
Answered
on Feb 17, 2011
