20 Most Recent OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Questions & Answers
3answers
Where can I download cummins NTA 350 engine repair manual?
We are Cummins diesel generator OEM. Can provide 24KW to 2400KW diesel power generator with Cummins engine. Also provide Cummins engine parts and user manual to clients. You can find the repair manual by Cummins engine official website or turn to supplier for help. https://www.dieselgeneratortech.com/cummins 1000kw cummins diesel generator-4g5wdwgei0pdvlmlmfm22efu-3-0.jpg
10/26/2018 1:40:31 AM • OTC 7471A... • Answered on Oct 26, 2018
2answers
There is problem with my cummins generator the is
check fuel filter it may be only getting enough fuel to run up to so many rpm
3/6/2018 2:40:38 AM • OTC 7471A... • Answered on Mar 06, 2018
S shaped wrench n14 cummins air compressor
I don't know what exactly do you need, but check out the service manual for any repair procedure you want to make. Cummins N14 Engines Service Manual
4/17/2015 10:16:37 PM • OTC 7471A... • Answered on Apr 17, 2015
2answers
Timing
to answer the first question:
the timing marks are on the accessory drive pulley. you will have an A, B, and C with a line at each one. you will line those up with the raised portion of the front gear cover. more likely than not, the letters are either painted over or rusted over, so they may be somewhat hard to spot. you will have to use a 1 5/16" socket to bar the engine over by the nut on the accessory drive pulley.
the second question: to removed the air compressor, you will need to disconnect all the lines going to and from the air compressor and fuel pump. this includes having to drain your coolant in order to disconnect the cooling lines to the compressor. you will need to remove fuel lines, air lines to the air governor, and anything else that may hang up. be prepared to replace any gaskets that you disrupt during this process, because they WILL leak if you do not. there are, if i remember correctly, 4 5/8" nuts that hold the air compressor on the accessory drive, 3 of them are relatively easy to get to, however the 4th, the one at the top closest to the block, must be removed with a special wrench, it is an S shaped wrench that you can buy from a snapon or matco dealer made specifically for that nut. once they are removed the compressor/fuel pump assembly should come right apart. if any damage is done to the accessory drive however, you must replace that as well, which could lead to a very large mess.
I myself work for Cummins, and have recently done this very repair for local cement company. I had to replace the accessory drive gasket due to a leak. Once the accessory drive was removed, I found that the accessory drive bushing in the gear housing had spun. That leads to a repair of having to replace the entire gear housing. To due so you must hoist the engine up and remove the front engine supports and removed that entire housing. So be warned, it may be a much more daunting task then it seems to appear.
Good Luck
4/17/2015 10:15:12 PM • OTC 7471A... • Answered on Apr 17, 2015
2answers
N14 celect or plus fuel mixing with oil
bad injectors it can be the o rings
4/17/2015 10:09:58 PM • OTC 7471A... • Answered on Apr 17, 2015
ENGINE CRANKS BUT WONT START REPLACED
sounds like ecm is not getting power. check powers and grounds at ecm,
4/6/2015 8:44:24 PM • OTC 7471A... • Answered on Apr 06, 2015
0answers
1682 fault code
Be the first to answer 10/17/2012 12:25:52 AM • OTC 7471A... • Posted on Oct 17, 2012Be the first to answer
Truck cummings 9800 valve settings
On the Celect,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you hand tighten screw until injector plunger bottoms out.Back screw out 2 flats,ie turn corner of lock nut to align with the rivet in the rocker lever(pushtube side),then back out screw two "corners" then tighten the jam nut down.Adjust the Injector first,then the valves. What is the CPL because it makes a different on injector setting.CPLs 821,833,903,904,& 806 are 105 INLBSCPLs 910,827,1185,1188,1210,1211,1256,&1280 are 90 INLBSCPLs 1374,1380,1395,1405,& 1507 are 125 INLBSOn the STC,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you torque to specs to bottom injector plunger.Then tighten the jam nut down.Adjust the Injector first,then the valves. On STC it would be greatly advised to run injector flush through the fuel system for an hour to clean carbon off injector tips to prevent plugging spray holes causing a missfire.Cummins sells it in a metal can & you sill need a return & suction line to hook up to engine(one at fuel inlet & one on fuel return) and run it out of the can. Firing order is 1,5,3,6,2,4
5/20/2012 1:11:51 PM • OTC 7471A... • Answered on May 20, 2012
I have a 2000 dodge ram 4x4 5.9 litre deisel. the
Are all of your dash lights coming on as usualy before you try restarting the engine - it could be that the pcm is becoming heat sensitive and needing to cool down before it can restart. time the falled restart time ( try starting it every minute and note it ) then take a bag of ice and put it on and around the pcm and check for any difference, if it restarts twice as fast with the ice replace the pcm. Hope this works for you, complements of Mike at Rock Creek Repair.
11/3/2010 3:33:52 AM • OTC 7471A... • Answered on Nov 03, 2010
tip
My 06-09 Cummins ISX is Stumbling and Surging
Often times I see this symptom and this tip will save you costly down time and a trip to the dealer.
If you are seeing this issue you may also find a code for EGR Delta Pressure are something simular.
This code is caused by the 2 hoses that the sensor uses to read the pressures filling with carbon and Soot that the EGR valve sends into the intake.
On the Left (Drivers Side) of the engine there is a sensor with 2 small hoses on it mounted on top of the Intake Pipe.
these hoses lead to the EGR mixer pipe that says HOT on it.
using a 5/8" wrench and a 1'4" socket for the hose clamps remove the Tubes and clean out the soot from both the tubes and the mixer with a solovent of some sort. also Blow out the fitings where the sensor mounts but do not use solovent here., reassemble and test and Voila.
all that is left is to buy me a beer....
Water contamination in lub oil.how to identify
most fuel oil mixing occurs at head cylinder gasket area. the area near pistons is most at risk.
4/5/2010 12:26:54 PM • OTC 7471A... • Answered on Apr 05, 2010
Engine QFB 4.5/ 6.7 is showing fault code EC02 and
Your engine won't start because it is detecting a low coolant level. But according to you it has coolant, meaning the sender or sensor is bad. If it is a sender it is very easy to bypass while you get the sender( very important to replace). It is a sender it will have one or two wires. To bypass, 1. If it has one wire ground it
2. If it has two wires join both of them. Remember to put the wires back to its place after replacing. If it is a sensor you won't be able to bypass and it has three wire, one positive a negative and a signal. If is a sender you will be able to bypass. After bypassing disconnect the negative terminal at the battery for a couple of minutes allowing the E.C.M. to reset. Hope this helps
4/1/2010 2:37:11 AM • OTC 7471A... • Answered on Apr 01, 2010
142 inch pounds to foot pounds
Divide by 12
3/9/2010 4:32:30 PM • OTC 7471A... • Answered on Mar 09, 2010
Is the keep to the cam when you install the
in and outlet both 0.15 mm.
3/3/2010 8:58:22 PM • OTC 7471A... • Answered on Mar 03, 2010
OTC 7471A CUMMINS DIESEL ENGINE BARRING TOOL - 7471A Logo
51 questions posted
Top OTC Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an OTC Hammering Expert? Answer questions, earn points and help others
View Most Popular
OTC Hammering
  • OTC Hammering
Most Popular Question
engine cranks but wont start replaced
  • Hammering
