20 Most Recent Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP Gas Powered Lawn Mower Questions & Answers
If it is system I am thinking about it does have an automated choke system and that it is out of adjustment
Briggs &... | Answered on Jun 05, 2015
Should be approx. 20 oz
Briggs &... | Answered on Mar 02, 2015
just get started, one step at a time . inspect what needs tobe removed to get to that carb good luck.
Briggs &... | Answered on Aug 18, 2014
Insert the rope through the handle from the bottom. Draw a tight knot on the very end of the rope and pull the knot back into the handle.
Briggs &... | Answered on Jul 23, 2014
check for water in gas in gas if not then flooding rebuild carb
Briggs &... | Answered on Jun 24, 2014
you need a valve job and have a unseated intake valve might have to get new motor if cant seat valve have to take to shop if cost 3rd by new mower
you still have oil in muffler buy new muffler or run like it is it will eventually stop smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Briggs &... | Answered on Jun 23, 2014
Try a new spark plug and then clean the
carb jets very carefully. Remove the jets
and blow out all the carb passageways.
The jets being plugged cause a lean fuel
mixture which causes the surging.
Last resort is check compression and do a
engine rebuild with new crankshaft seals.
Briggs &... | Answered on Jun 15, 2014
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
Briggs &... | Answered on Jun 07, 2014
There should be a square of plastic on the side of the engine which is opposite of the muffler. It has a small hex head with a slot cut in it. Remove this plastic cover and the air cleaner should be inside of it.
Briggs &... | Answered on May 23, 2014
I had bought (used) the same mower, and had the same problem.
What it turned out to be was a safety switch (that won't allow fire to the plug unless either the catch bag or the mulch plug is installed), wasn't working!
BUT...mine wouldn't get fire even if the bag/plug was installed!
On the same side as the carb is on, there should be a wire bundle (running underneath the carb) covered by a corrugated plastic wire covering, AND a single wire with a connector right about even with the carb.
This single wire is for the safety switch.
CAREFULLY unplug the connector, separating the single wire, and try starting the mower.
If it starts (or you NOW have fire to the spark plug), the problem is the switch.
While the switch could be bad, it might also be dirty.
When I removed the plastic cover over the switch, the area was covered with dried out grass clippings.
I used a 3" paint brush and a can of compressed air (like one uses to clean a computer), and cleaned it all out.
When I reconnected the switch wire, it worked as it should.
If the switch IS bad, you can just leave the wire disconnected and run it that way, BUT the safety feature (bag/plug must be in place) won't work.
Briggs &... | Answered on May 20, 2014
Check oil may have low oil shutoff and drain gas and start with new
Briggs &... | Answered on Feb 25, 2014
Where is the fuel coming from? If it is coming from the button of the carb, you may have a bad gasket around the nut that holds the bowl on the carb. If it is coming out from the top of the bowl, you may have a bad gasket ring that goes around the perimeter of the bowl. In addition, if the needle is not positioned correctly in the seat, you may not be closing off fuel. If the needle gets stuck in the down position, your carb will continuously get fuel, and the float will not shut off the flow. Have you tried to take the carb off, or at least remove the bowl to inspect things?
Briggs &... | Answered on Aug 20, 2013
First, follow your throttle cable down to the carb. Locate the clamp that holds the housing in place and loosen it just enough to move the cable. Start the mower and adjust the idle by the screw that touches the same plate that your cable hooks to. Then push the throttle control to idle and retighten the cable clamp.
Briggs &... | Answered on Jun 16, 2013
Briggs & Stratton Lawn-Boy 10640 20-Inch 6.5 HP  Gas Powered Lawn Mower  Logo
74 questions posted
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
JOHN LAPIER
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
View Most Popular
  • Briggs & Stratton Garden
Most Popular Question
started lawn boy
  • Garden
