20 Most Recent
Kelty Yard King 21" Push Lawn Mower w/ Briggs and Stratton Engine - 96137001200 Questions & Answers
Fuel tank
Take it to a traditional plumber, who can work with solder to have it soldered, or anyone who can do soldering.
How do you change the
If there is no drain plug in the crankcase bottom (under deck), then look for a square-head type plug on the engine side near bottom. If none there, then the mower will have to be tipped on it's side and the oil drained out of the oil fill tube.
Mower blade is spinning loose is not connected to
Don't ever run a mower with a loose blade. Most push mowers have a blade adapter that slips over the engine shaft and allows the fastening bolt (and it should be a special hardened one with 6 lines on the head of it) to thread into the end of the crankshaft. The adapter could have slipped and needs to be repositioned on the shaft so that the blade can be properly tightened.
Not wanting to start
fuel line or filter could be clogged, the spark plug or wire could be bad, etc.
Clutch cable for a sprint 21
Certain ace hardware or true value hardware stores have small engine repair shops they should be able to order the part for you call around first.
It just stoped but will not start again
Hi, if it cut out whilst running it has either ran out of fuel or ignition. Please make sure you have plenty of fuel in it. This sounds like an ignition problem. Take the plug lead off the spark plug and stick a metal blade screwdriver into the end of the lead, then hold the screwdriver close to any piece of metal on the cylinder head close to where the spark plug screws in and get some one to crank it over by pulling the cord and holding the throttle as if you were trying to start it. You should get several sparks to jump from the screw driver across to the metal. If not you have a problem that involved a considerable amount of knowledge and stripping down of the engine covers etc to get to the offending items.
