20 Most Recent Oregon Scientific Oregon Chainsaw chain for Stihl Chainsaw 20" Bar Length 72 Drive links 3/8 Standard 0.05 Gauge Chiesel Chain Questions & Answers
start by cleaning the air filter, blow it out realy good, alot of times the carb gets dirty spray some carb cleaner in it just a little at a time, if you haven't changed the plug i would do that too.
Oregon... | Answered on Mar 16, 2010
There is no one gauge that is common to all new Stihl saws. Gauge is completely dependent on the bar chosen.
The standards are 0.043, 0.050, 0.053. 0.058, 0.063, 0.080.
You should be able to find your chain gauge on the bar. Even if the paint is worn away, you should see the impression from the stamping. If all else fails, take the chain into a Stihl shop and they will have no problem finding what you need.
Oregon... | Answered on Dec 17, 2009
The centrifical clutch is probably rusted (or has a broken spring). You can try a small amount of WD-40 inside the clutch to see it that will break it loose.
Also, be sure that the chain tension adjustment is not too tight!!
Oregon... | Answered on Oct 12, 2009
28866.png This is the only diagram that is offered for this model but on the multifuntion switch (#33) The wire is layed through the upper part of it with the metal connector sticking out of the left side and once there you will pull the wire to the right until the metal connector is seated in the switch. After this reinstall the switch into the handle houseing and make sure that the contact spring (#24) is sitting on top of the switch and when in the off possition making contact with the metal conector of the wire on the switch.
Oregon... | Answered on Jun 13, 2009
This isn't a 100% solution, but a saw only runs as clean as the air filter, and they get dirty quick. I give my air filters a quick wash about 5-7 times with just soap / water.
If that doesn't do the trick, your probably looking at some kind of carburetor issue.
Oregon... | Answered on May 27, 2009
change the batteries and leave it near the main unit for a while to get a signal back
Oregon... | Answered on Feb 27, 2019
perhaps just buy a new one complete . there .
Oregon... | Answered on Apr 14, 2018
you should just post any question one time.
Oregon... | Answered on Dec 01, 2017
Use a volt meter to see if the battery is depleted or not. If you replace the battery and the alarm stops then it was a weak battery, If it keeps on then there something setting it off. You can use the information in the owners manual Oregon Scientific BAR629HGU Manuals to troubleshoot it.
Oregon... | Answered on Jul 10, 2016
Oregon Scientific Oregon Chainsaw chain for Stihl Chainsaw 20" Bar Length 72 Drive links 3/8 Standard 0.05 Gauge Chiesel Chain Logo
6 questions posted
Top Oregon Scientific Measuring Tools & Sensors Experts
Marvin
Marvin
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Oregon Scientific Measuring Tools & Sensors
Most Popular Question
chain gauge current stihl chainsaws
  • Measuring Tools & Sensors
