20 Most Recent
Standard Oregon Chainsaw Chain For Mcculloch Chainsaw 18" Bar Length 64 Drive Links 3/8 0.05 Gauge Chiesel Chain Questions & Answers
McCulloch 120 Chainsaw Owners Manual
McCulloch Manuals
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join).
http://www.arboristsite.com/showthread.php?t=72322
Include your e-mail address in your request or it most likely will not be answered.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
McCulloch Mac 120 oiler
I think the problem is the funny rubber-hose-connection of the oil tank to the oil pump. It looks quite flimsy to me... But if you want I can have a look how this screw is adjusted...Bye, also tom
Putting chain on saw
I am assuming your saw has an outboard clutch (most Macs do).
Please see page 16 here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2005/HOUS2005_1140247-95.pdf
It is possible to install it backward look colsely at the orientation in the second illustration from the bottom, left column.
New chains stretch Please for your safety watch it and tighten when needed.
Chain Adjustment
- Make sure the chain brake is off (gloves will protest your fingers).
- If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
- Ease the tension adjustment until the chain is obviously loose.
- Using one hand, hold the nose of the bar up.
- While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
- Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
The second hand McCulloch 120 chainsaw I purchased
I think the pre-adjust settings are to turn jets in all the way and back out 1.5 turns each. then:
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Sovereign chainsaw
Probably is none. Take off the chain cover and the chain and clean out all the sawdust and chips where the oil comes out to oil the chain and bar. An old toothbrush works well.
6/18/2014 6:57:06 AM •
Standard...
Answered
on Jun 18, 2014
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
How can I adjust the time on my weather station model #sgr72914?
- Access the Time Setting Mode:
- Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
- Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
- Adjust Hour and Minutes:
- Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
- After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
- Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
- Confirm the Time:
- Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
- Check the Time Display:
- After setting the time, check the display to ensure that the time is displayed correctly.
