20 Most Recent Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8 0.05 Gauge Chiesel Chain Questions & Answers
What is the spark plug gap on a MS210?
According to page 62 in the Stihl user manual: Spark plug (resistor type): Bosch WSR 6 F Electrode gap: 0.02 in. (0.5 mm) http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-MS-210-230-250-Instruction-Manual.pdf
9/17/2015 6:34:20 PM • Standard Oregon... • Answered on Sep 17, 2015
Im having problems starting an MS250 Stihl chainsaw. Can you give
Chances are good that the compression is not to blame. I would look at:
1. Bad Fuel
2. Fuel Line/filter
3. Carb dirty/mis adjusted
3. Spark Plug
4. Ignition
3/28/2015 1:05:14 PM • Standard Oregon... • Answered on Mar 28, 2015
2answers
Chainsaw will start but will
1. Check Idle settings.
2. Check Spark plug some plug is bad if engine heating!
3. Check all sealings, first check gaskets between cilinder and carburator, then crancase sealings.
6/25/2013 8:51:19 PM • Standard Oregon... • Answered on Jun 25, 2013
My stihl chainsaw pull start is stuck it died while running and i couldnt pull the string to start again
sounds like the engine has seized up. SORRY. did you mix the fuel with 2 cycle oil?
6/23/2013 11:58:00 PM • Standard Oregon... • Answered on Jun 23, 2013
018c oiler
ck.the oiler drive gear behind the chain sproket
6/23/2013 11:02:34 PM • Standard Oregon... • Answered on Jun 23, 2013
My stihl ms250 wont shut off
there's a wire that gors from chassis ground through a switch to the coil. look for a broken wire.
4/30/2012 1:31:54 AM • Standard Oregon... • Answered on Apr 30, 2012
Sir I ,VIVEK want to know how to read physics
This depends on the language you are best at reading. Many great physisists have come from Germany and Austria. You may want to look into the language that is best understood by you.
Special Therory is difficult enough to usderstand in your good language let alone a foreign one ;)
Good luck
Joe
4/8/2011 4:16:15 AM • Standard Oregon... • Answered on Apr 08, 2011
No chain oil comeing through
remove chain plate, clean all check oil drain is clean. check oil tank cap, is ther air inlet clean.
3/18/2011 11:27:39 AM • Standard Oregon... • Answered on Mar 18, 2011
Will start, but bogging down. was told its the
check also gaskets between cilinder and carburator.
3/18/2011 11:26:25 AM • Standard Oregon... • Answered on Mar 18, 2011
Chain keeps working loose after
33RS chain goes dull faster because it is a full chisel chain. Stihl chain is prestretched and will only stretch if heat builds up. Make sure your oiler is putting out more than .3 ounces per min at 13,000 rpm and if any chrome is peeled off of the chain swap it for a good one. Dirt takes less than .003 of a second to dull an entire chain.
check with a local dealer like www.arcolawn.com to see if your machine can be fitted with a carbide chain that can last up to 4 times as long in dirt and hard wood.
2/22/2011 4:55:58 AM • Standard Oregon... • Answered on Feb 22, 2011
Stihl 034 super kick on start up
I would recommend checking the flywheel key. It is not common but if the clutch had been removed with an impact gun it may have sheared the key. You can do this by removing the starter and flywheel.
consult a local dealer like www.arcolawn.com for Stihl parts and tools.
Best wishes,
2/21/2011 1:42:17 AM • Standard Oregon... • Answered on Feb 21, 2011
Standard Oregon Chainsaw Chain For Stihl Chainsaw 24" Bar Length 84 Drive Links 3/8  0.05 Gauge Chiesel Chain Logo
67 questions posted
Top Standard Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Standard Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Standard Measuring Tools & Sensors
Most Popular Question
coil gap stihl 034
  • Measuring Tools & Sensors
