20 Most Recent XX-67A II LED/Valet Switch Pod Questions & Answers
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
1/13/2010 1:41:21 PM • XX-67A II... • Answered on Jan 13, 2010
Installation of a Viper 5901 remote start into a
viper 5901 remote start alam installing it on a 1997 ford explore i need a detail wiring diagram
7/9/2009 5:24:21 PM • XX-67A II... • Answered on Jul 09, 2009
Crimestopper SP502 usb remote wont hold charge
If your Crimestopper SP502 USB remote isn't holding a charge, there could be a few potential reasons for this issue. Here are some steps you can take to troubleshoot and potentially resolve the problem:
  1. Check the Battery: Make sure the remote's battery isn't damaged or worn out. If the battery is old or not functioning properly, it might not hold a charge. If possible, replace the battery with a new one and see if the issue persists.
  2. Charging Cable and Port: Ensure that you are using a functional charging cable and connecting it to a working USB port. Sometimes, the issue might not be with the remote but with the charging equipment.
  3. Cleaning: Sometimes, debris or dirt can accumulate in the charging port of the remote, preventing a proper connection with the charging cable. Gently clean the charging port using a small brush or compressed air.
  4. Resetting the Remote: Try performing a soft reset on the remote. This might involve holding down certain buttons or combinations of buttons for a specific duration. Refer to the user manual for your Crimestopper SP502 for instructions on how to do this.
  5. Firmware Update: Check if there's a firmware update available for your remote. Sometimes, firmware updates can improve the device's performance and battery life.
  6. Contact Customer Support: If none of the above steps work, consider reaching out to Crimestopper's customer support for assistance. They might be able to provide further troubleshooting steps or suggest a solution.
  7. Battery Calibration: In some cases, calibrating the battery can help improve its performance. Fully charge the remote, then use it until the battery is completely drained. Repeat this process a couple of times to see if it helps the battery hold a charge better.
  8. Replace the Remote: If the remote is still not holding a charge after trying the above steps, it's possible that there's an internal hardware issue. In this case, you might need to consider replacing the remote.
Remember that the specific steps you should take may vary depending on the model of your Crimestopper SP502 remote and the instructions provided in its user manual. If you're uncertain about any step, it's a good idea to refer to the manual or seek assistance from the manufacturer's customer support.
8/9/2023 10:19:22 AM • Crime Stopper... • Answered on Aug 09, 2023
I need a video or wiring diagram for a Crime Stopper Cool Start RS4-G5 wired to 2007 Chevy Equinox please.
Question edited to add a few capital letters. Videos and instructions in the link https://www.google.com/search?q=crime+stopper+cool+start+Rs4-g5 ..
7/16/2022 9:08:10 PM • Crime Stopper... • Answered on Jul 16, 2022
Vehicle wont start with sp101 alarm
under the dash by the steering column you will see some wires that dont belong and a small black box about a inch square two wires will go up and into the steering column there will only be two that come from the box cut the wires that go to the box and connect them together its the starter disable . removing the blk box it should start
2/3/2019 9:08:59 AM • Crime Stopper... • Answered on Feb 03, 2019
I purchased a crime stopper remote starter for a 2003 mazda6 with bypass. I have it installed but cannot program the bypass any tips or suggestions on what I am doing wrong??
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u .. U can also get free manuals
1/29/2019 8:27:50 AM • Crime Stopper... • Answered on Jan 29, 2019
How program crime stopper remote control # CHX433TX of 6 buttons
1/29/2019 8:18:48 AM • Crime Stopper... • Answered on Jan 29, 2019
My crime stopper remote start only clicks. When I take it to the shop it only takes like 1 minute to fix.. What do you think they do?
why don't u try online websites.. some websites deal in it real time.. along with solutions to problems how to repair fix service nd all let me know if u need help I know plenty
1/28/2019 10:10:49 AM • Crime Stopper... • Answered on Jan 28, 2019
I bought a used car which came with a Crime Stopper remote start fob. I need to learn how to use it. Help please.
Search Free Remote Programming.com for better info
2/10/2017 8:12:15 PM • Crime Stopper... • Answered on Feb 10, 2017
How do i reprogram my remote?
Sometimes if you press both remote buttons on a transmitter at the same time next to the vehicle for more than 10 seconds it will reprogramme a remote
5/14/2016 3:56:05 PM • Crime Stopper... • Answered on May 14, 2016
Renault Megane is draining the battery over night,
I would have your alternator and battery checked after doing a simple inspection of all your power functions. If something is draining the battery fully overnight your battery may not be getting fully charged, or the battery may be old. If the vehicle only does city driving - then once a week you need to dive the vehicle at least 20 minutes of straight driving so the battery gets charged more than it needs for everyday operation of the vehicle.Simple inspection: Check all electronic devices from radio, tv, phone chargers, interior lights are working properly and fully shut off. If a switch is half way, example; interior lights set from "door to on" the light may not be on - but there is a slight draw all the time on the battery.Once we had our dashboard light on all the time but it was turned down so faint with the dimmer switch you could not tell it was actually on. It seems like a simple thing but it drove us crazy for two days until we discovered what was up.If everything checks out then you need to see a mechanic. One thing you can look for under the hood or dashboard is that all wiring is properly sheathed and there is no damage to the insulation around the wires. Again, have them inspect the alternator, (battery charging system), and the battery. An alarm system by itself should not be that taxing to drain your battery overnight.Best of Luck.
10/4/2013 2:55:17 PM • Crime Stopper... • Answered on Oct 04, 2013
I need areplacement for RS-1303.DPii
You can purchase the remotes directly from Crimestopper or call them to direct you to a dealer near you. Their contact and order information can be found at this link:
Crimestopper contact page
The following 2 links will help you identify which remote you need.
Remote chart by system number
Remote identification by image
11/10/2010 8:55:03 PM • Crime Stopper... • Answered on Nov 10, 2010
Intermitant car alarm problems on a 96 ford fiesta
I really don't think you have an immbobilizer, but if you are handy.. look behind dash at ignition harness try and find a blk/blu or grey wire, see if it is cut going to a relay of some sort, if so cut relay out and recoonect wires back together, see if car starts ....
1/26/2009 6:19:25 PM • Crime Stopper... • Answered on Jan 26, 2009
Van alarm is draining battery flat over night
I doubt it is the alarm, but a simple way of checking is to unplug it.. look under drivers dash for an aftermarket box, unplug the connections (after charging battery) and wait till next day.. I think you might have a diff issue (I have installed these for over 10 years and never seen one actually discharge a battery)
1/26/2009 5:22:38 PM • Crime Stopper... • Answered on Jan 26, 2009
Remote will not work now
if the ant. for the system was mounted on glass it may have been disconected or if it was placed near top of dash it could have been broke or pinched thats where i would start
1/9/2009 7:22:55 PM • Crime Stopper... • Answered on Jan 09, 2009
2001 Cadillac Deville Northstar Engine thermostat location
4.6 Northstar V8. It is located on the rear of engine (driver side) in front. It is in the the water pump housing cover. Remove air box and intake tube and bottom radiator hose. 2 bolts(believe 10mm) on thermostat housing. These systems are a little finicky about air pockets....so fill slowly and let run at idle until operating temp and let cool and check level.....fill as needed and repeat if needed.
3/28/2024 3:46:39 AM • Vehicle Parts &... • Answered on Mar 28, 2024
Peugeot expert central locking not working
A faulty central locking system might be due to several reasons, such as a blown fuse, faulty solenoid, or electrical wiring issues. Also, it's good to remember the fault might not be with the central car locking system but the key fob instead; over time, fobs require battery changes.
3/24/2024 2:38:44 PM • Vehicle Parts &... • Answered on Mar 24, 2024
XX-67A II LED/Valet Switch Pod Logo
Popular Tags
2 questions posted
Top Crime Stopper Vehicle Parts & Accessories Experts
John
John
ADMIN Andrew
ADMIN Andrew
oneStan
oneStan
Are you a Crime Stopper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Crime Stopper Vehicle Parts & Accessories
Most Popular Question
just need diagram r nshowing install
  • Vehicle Parts & Accessories
