20 Most Recent Uniden DCX640 Cordless Expansion Handset (unidcx640) Questions & Answers
0answers
0answers
My extra handset keeps saying welcome please wait
As long as your expansion handset is running on the same frequency as your primary handset, your problem is most likely that your expansion handset needs to be "mated" back to your primary base unit. Try removing and then replacing the battery, and then placing your expansion unit on the primary "home-base" charger. If that does not fix the issue, then you most likely have a faulty handset and will have to exchange it for a new one or send that one in for repair, depending on how long age you purchased it and how long your warranty is good for. Anyways, I hope this helps get you back to talking!
Have a nice day!
2/22/2009 1:07:26 PM • Uniden DCX640... • Answered on Feb 22, 2009
Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
11/23/2008 3:54:48 PM • Uniden DCX640... • Answered on Nov 23, 2008
I have a 88 message on my uniden power max 5.8, model tru9480-3. can i get rid of that if the base is not in service.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time. With.the.phone.in.standby, .press.[ ].to. delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are. permanently.deleted. https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual ..
12/29/2023 1:04:31 AM • Uniden Lands... • Answered on Dec 29, 2023
I have a UNIDEN AS 8116-2 phone, I have lost the user manual. I need to know how to change handset 2 to handset 1 for UNIDEN AS 8116 phone
Uniden Support - Downloads and Manuals
uniden.info https://www.uniden.info > download Uniden Support - Downloads and Manuals. Missing: 8116-2 ‎' Must include: 8116-2
6/16/2023 4:25:25 AM • Uniden Lands... • Answered on Jun 16, 2023
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 . I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes. Cindy Wells
5/2/2023 9:42:31 PM • Uniden Lands... • Answered on May 02, 2023
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay. I hope this helps. Cindy Wells
3/1/2023 1:07:49 AM • Uniden Lands... • Answered on Mar 01, 2023
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
  1. Disconnect the power cord from the base of both phones.
  2. Take the battery out of each handset.
  3. Wait for a few minutes.
  4. Reconnect the power cord to the base of the newer version phone and insert its battery.
  5. Wait for the phone to register on the base, which should take a few seconds.
  6. Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
  7. The older version phone should now register on the same base.
  8. Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
2/24/2023 10:11:23 PM • Uniden Lands... • Answered on Feb 24, 2023
My mother has a Uniden SS E45 +1 phone and it keeps flashing but there is no message. How do I fix it for her?
It may be that the message is held by the Telco. Phone the supplier and ask. You dial in with a special number and PIN.
2/20/2023 7:15:03 PM • Uniden Lands... • Answered on Feb 20, 2023
Uniden Phone. How to unblock a number please?
Question edited for clarity. Question moved from Computers. Help in the link https://www.google.com/search?q=Uniden+Phone.+How+to+unblock+a+number ..
2/20/2023 7:11:08 PM • Uniden Lands... • Answered on Feb 20, 2023
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee. Cindy Wells (Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
1/30/2023 1:22:13 AM • Uniden Lands... • Answered on Jan 30, 2023
Uniden DCX640 Cordless Expansion Handset (unidcx640) Logo
15 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
handset fails register
  • Lands Phones
