20 Most Recent Cadence Weider 840 Treadmill Walking Belt-14" Questions & Answers
When i am walking on the band it seems as if i am
This could be 1 of 3 things. Either the walking belt need to be tightened, or the rubber motor belt is slipping (under the front hood) or the pulley has come loose from the roller.
First tighten the walking belt using the allen key provided when you purchased the machine. Locate the 2 adjustment bolts at the back of the machine and tighten (clockwise) both bolts 1 turn. Retry the machine. If there is no noticeable difference, remove the hood and see if the rubber belt is slipping. If so tighten the belt by adjusting the motor.
12/18/2010 6:31:58 AM • Cadence Weider ... • Answered on Dec 18, 2010
Good morning, do you stocka front roller traction
You will need to buy the newer front roller it addresses the issue of the sleeve coming off. Go to iconfitness.com then to customer service then replacement parts and put Cadence 840 and the parts and pricing for the unit will be their.
2/28/2010 9:22:49 AM • Cadence Weider ... • Answered on Feb 28, 2010
Cadence 10 no power when turned on.
Hi, Please test the wires that connect your speaker to the power source and use a multimeter to check whether any power is coming through the wires when the main power source is turned on. You could measure volts and/or ohms with the multimeter. Thank you.
10/6/2022 1:29:06 AM • Cadence Exercise... • Answered on Oct 06, 2022
0answers
My cadence used to stop and start.Now nothing is working
If you wish to get some details; check the site linked here. Pull up older posts..... http://electro-medical.blogspot.com/
5/11/2016 3:38:42 PM • Cadence Exercise... • Answered on May 11, 2016
I just turned my desk I cadence 5.9 on and it is super loud. I have walked On a few treadmills and they have never been this loud....is this normal?
Well it could be that the motor may be broken . Or worst case the chain that makes the floor move may have snapped
3/13/2016 5:21:53 PM • Cadence Exercise... • Answered on Mar 13, 2016
0answers
0answers
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you Instructions 1.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
11/14/2013 11:54:35 AM • Cadence Exercise... • Answered on Nov 14, 2013
Belt is slipping and squeaking when walked upon
Sounds like the motor belt is slipping. Make sure the belt from the motor to front roller pulley is tight.Once you have that adjusted lube and adjust the walk belt. The squeaking is usually from the motor belt. Many treadmills(Proform, Nordictrack for example) use Silicone lube (lube n walk, or silicone With teflon from Lowes works good) Call the manufacturer to make sure it uses a silicone lube.
10/15/2013 7:08:31 PM • Cadence Exercise... • Answered on Oct 15, 2013
When I walk on my cadence 285 it sows down
lube the de deck belt +rollers bearing front and rear +test the drive belt motor and replace. see the video and fix it. God bless you
6/11/2013 11:41:34 AM • Cadence Exercise... • Answered on Jun 11, 2013
Cadence Weider  840 Treadmill Walking Belt-14" Logo
2 questions posted
Top Cadence Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Cadence Exercise & Fitness
Most Popular Question
good morning stocka front roller
  • Exercise & Fitness
