20 Most Recent
Nordic Track Nordictrack Apex 6500 Reflex Technology Treadmill Questions & Answers
The walking belt on my
if it is moving to the right you must tighten the right side of the rear roller
you are doing wrong side
Need to disassemble NordicTrack X7i trainer to
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
How do you change speed from KPH to MPH
To select the settings mode, first remove the key from the console. Then, hold down the Stop button while reinserting the key into the console.When the settings mode is selected, the display will show the word ENGLISH or METRIC to indicate which system of measurement is selected. To change the system of measurement, first highlight UNITS and press the User/Enter button. Next, press the increase or decrease button beside the User/Enter button to select the desired system of measurement. Then, press the User/Enter button.To exit the settings mode at any time, remove the
NordicTrack treadmill EXP 1000
Please note that these instructions don't apply to all models of treadmills. Many recent models, including all models with touchscreen consoles, do not have the capability for the user to calibrate the speed.
Speed calibration is a process that is used to correct imbalances in the machine's operating speed.
Please note that this procedure involves pushing the machine to its maximum speed very quickly. Do NOT stand on the treadmill while performing this procedure.
First, you need to enter calibration mode on the console. To do this, press and hold the STOP and SPEED INCREASE buttons (this will be either an up arrow or a + (plus) symbol). While holding these buttons, insert the safety key onto the console. This will cause the machine to go into calibration mode. After this has occurred, you may let go of the buttons and the safety key.
Next, press the stop button once. This will enter advance the screen to the next feature of calibration mode. As said previously, do not stand on the treadmill while performing this procedure. Press and hold the speed increase button. Watch the console. You will see a number on the display that will increase as you hold the speed increase button. Continue to hold the speed increase button until the number changes to "85." This will take the treadmill to its maximum speed, which will also be displayed on the console. Please note that the example below only demonstrates the console displaying "85", not the treadmill's operating speed.
