20 Most Recent Yukon Butt & Thigh Shaper Questions & Answers
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Exercise &... | Answered Yesterday
  1. Plug your charging cable into the USB port and insert the other end into the port on the back of your Fitbit Charge HR. Your Charge HR will begin charging.
  2. Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V122").
  3. Let go of the button.
  4. Unplug your tracker from the charging cable.
  5. Also, I suggest cleaning your tracker's battery contacts, because over time the contacts can accumulate dirt and debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this can damage the plating and result in corrosion.
Finally keep in mind that these tips can impact the battery life:
  • Each alarm you add up to the maximum of 8 reduces battery life by a small percentage.
  • Frequently pressing the button to check your statistics or the time may reduce the battery life.
  • Since Quick View causes the screen to light up whenever you turn your wrist towards you, turning this setting off may prolong battery life. When Quick View is off, press the button to see your stats.
  • If you're syncing with an Android device, the Always Connected option may reduce battery life.
  • If you're syncing with any Fitbit app, the All-Day sync option may reduce battery life on both the tracker and mobile device.
  • Charging your Charge HR in extreme heat or cold may reduce battery life.
  • If you don't need a heart rate rating, change the Heart Rate setting to Off. The Auto setting uses less battery than the On setting...
If you wish to get some details treadmill error codes and calibration ; check the site linked here. http://electro-medical.blogspot.com/
Spray wd 40 or other lubricant on the tube that slides to see if it will free up .
Exercise &... | Answered 2 days ago
fixya doesnt sell anything
Contact a vendor to request a manual.
Examples:
https://www.ebay.com/itm/113216559908?ul_noapp=true
Sears, Walmart, etc. sell it.
Exercise &... | Answered 3 days ago
Here it is :
http://www.totalgymdirect.com/manual.php
Thank you !
Exercise &... | Answered on Apr 22, 2019
Yukon Butt & Thigh Shaper Logo
Popular Tags
1 questions posted
Top Yukon Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Tom Chichester
ray gallant
ray gallant
Are you a Yukon Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Yukon Exercise & Fitness
Most Popular Question
what is linear counter balance what is t
  • Exercise & Fitness
