20 Most Recent Umbra Otto Automatic Soap Dispenser Questions & Answers
No, 120/80 is average but individuals can run different blood pressures based on their health.
Health & Beauty | Answered 6 hours ago
Isotroin 5mg Buy Isotroin 5 mg Online, benefits, side effects, uses
Health & Beauty | Answered 9 hours ago
Herbal and homeopathic remedies Have Been used for man years to Provide support for naturally entertained by the digestive system and gastrointestinal problems highlighted. These remedies are safe and gentle to use on the body's system without any harsh side effects. Herbs: such as Matricaria recutita (German Chamomile) and Filipendula ulmaria (Meadowsweet) support health in Ongoing entertained by the digestive system and stomach lining And Also act as a tonic and a soothing remedy. In Addition, Ulmus fulva (Slippery Elm) and Sutherlandia frutescens Promote healthy levels of digestive acids in the stomach and absorption of nutrients
Health & Beauty | Answered 11 hours ago
The lights flash in a systematic sequence which reveals an VSI error code. Count the number of flashes.
1. Battery needs charging
2. Left motor bad connection
3. Left motor shorted
4. Right motor bad connection
5. Right motor shorted
6. Unplug battery charger
7. Joystick fault. Make certain the joystick is in the neutral position (centered) before turning on the controller
8. Controller fault. Check connections
9. Parking brakes bad connection. Check connections to parking brake, motor and controller
10. Excessive voltage. Check battery charger connections.
Health & Beauty | Answered 15 hours ago
Check the batteries, if they are older, they may not be charging like they should and don't provide the proper voltage.
Health & Beauty | Answered 22 hours ago
You should do a google search as the causes range from muscle ache to heart attack.
Health & Beauty | Answered 23 hours ago
**** companies spend hundreds of millions of dollars to develop a ****. They need to make that money back otherwise they would not spend money to develop drugs. Once the patent coverage runs out, other companies can product the **** without having all that debt, so they can offer it at lower price.
Health & Beauty | Answered Yesterday
Good for you.
Do a google search to find it is similar to codine
Kamagra is a **** that's sometimes used for erectile dysfunction (ED). It contains an active ingredient called 'sildenafil citrate', which is used in ******s and generic Sildenafil.
Kamagra comes either as a tablet, or as an oral jelly. It's usually bought online as a cheap alternative to Viagras or Levitra, and it's thought to work in a similar way.
But, Kamagra is currently unlicensed (not an approved, legal treatment) in the UK and the EU, so it can't be prescribed to you by a doctor. Because of this, it isn't regulated, so the exact ingredients and side effects of Kamagra can vary, and using it is unsafe and potentially dangerous.
low blood pressure dangerous only if it causes
noticeable signs and symptoms, such as:
Dizziness or lightheadedness
Fainting (called syncope )
Dehydration and unusual thirst - Dehydration can sometimes
cause blood pressure to drop. However, dehydration does not
automatically signal low blood pressure. Fever, vomiting, severe
diarrhea, overuse of diuretics and strenuous exercise can all lead
to dehydration, a potentially serious condition in which your body
loses more water than you take in. Even mild dehydration ( a loss
of as little as 1 percent to 2 percent of body weight ), can cause
weakness, dizziness and fatigue.
Lack of concentration
Blurred vision
Nausea
Cold, clammy, pale skin
Rapid, shallow breathing
Fatigue
Depression
Low blood pressure can occur with:
Prolonged bed rest
Pregnancy - During the first 24 weeks of pregnancy, it's
common for blood pressure to drop.
Decreases in blood volume - A decrease in blood volume can
also cause blood pressure to drop. A significant loss of blood
from major trauma, dehydration or severe internal bleeding
reduces blood volume, leading to a severe drop in blood pressure.
Certain medications - A number of drugs can cause low blood
pressure, including diuretics and other drugs that treat
hypertension; heart medications such as beta blockers; drugs for
Parkinson's disease; tricyclic antidepressants; erectile dysfunction
drugs, particularly in combination with nitroglycerine; narcotics
and alcohol. Other prescription and over-the-counter drugs may
cause low blood pressure when taken in combination with HBP
medications.
Heart problems - Among the heart conditions that can lead to
low blood pressure are an abnormally low heart rate
(bradycardia ), problems with heart valves , heart attack and heart
failure . Your heart may not be able to circulate enough blood to
meet your body's needs.
Endocrine problems - Such problems include complications with
hormone-producing glands in the body's endocrine systems;
specifically, an under-active thyroid (hypothyroidism), parathyroid
disease, adrenal insufficiency (Addison's disease), low blood
sugar and, in some cases, diabetes.
Severe infection (septic shock) - Septic shock can occur when
bacteria leave the original site of an infection (most often in the
lungs, abdomen or ******* tract) and enter the bloodstream. The
bacteria then produce toxins that affect blood vessels, leading to
a profound and life-threatening decline in blood pressure.
Allergic reaction (anaphylaxis) - Anaphylactic shock is a
sometimes-fatal allergic reaction that can occur in people who are
highly sensitive to drugs such as penicillin, to certain foods such
as peanuts, or to bee or wasp stings. This type of shock is
characterized by breathing problems, hives, itching, a swollen
throat and a sudden, dramatic fall in blood pressure.
Neurally mediated hypotension - Unlike orthostatic
hypotension, this disorder causes blood pressure to drop after
standing for long periods, leading to symptoms such as dizziness,
nausea and fainting. This condition primarily affects young people
and occurs because of a miscommunication between the heart
and the brain.
Nutritional deficiencies - A lack of the essential vitamins B-12
and folic acid can cause anemia, which in turn can lead to low
blood pressure.
Severely low blood pressure can have underlying causes that may:
Be an indication of serious heart, endocrine or neurological
disorders
Deprive the brain and other vital organs of oxygen and
nutrients, ultimately leading to shock, which can be life
threatening
You should see a professional to assist with your issue.
Umbra Otto Automatic Soap Dispenser Logo
1 questions posted
Top Umbra Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you an Umbra Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Umbra Health & Beauty
Most Popular Question
soap no longer dispenses automatically
  • Health & Beauty
