20 Most Recent Uniden TRU8888 Corded Phone Questions & Answers
0answers
Reset base
Be the first to answer 8/12/2014 3:16:41 AM • Uniden TRU8888... • Posted on Aug 12, 2014Be the first to answer
manual
Anyway to reset the main base unit for a TRU8888?
To Reset The Main Base of a TRU8888:
Hard Reset: With Power off, Press and Hold Delete and Volume Up on main base and plug power back in (holding the buttons until you hear the successful beep)
Soft Reset: With Power off, Press and Hold Do Not Disturb and Volume Up on main base and plug power back in (holding buttons until you hear the successful beep)
3/4/2011 9:34:01 AM • Uniden TRU8888... • Answered on Mar 04, 2011
When receiving a call, the person making the call
try receiving calls from other persons and see if problems still continues.
if it does, contact your customer care immediately
1/21/2011 5:42:37 PM • Uniden TRU8888... • Answered on Jan 21, 2011
Voice says
try deleting all the message that are on the phone as it is to FULL
2/28/2010 6:15:24 PM • Uniden TRU8888... • Answered on Feb 28, 2010
TRU8888 Base Unit - No Dial Tone After Power Failure
get a new phone
8/29/2009 4:10:55 PM • Uniden TRU8888... • Answered on Aug 29, 2009
Uniden TRU888 5.8 Digital Phone Display no longer lights up
I purchased this model phone as a refurb item and also had display blanking out issues. Mine related to a problem with the battery, which new batteries fixed. Try swapping the batteries between handsets and see if the fault moves to the other handset, which will prove if it is a battery problem. Otherwise, it would seem to be an internal fault in that handset. Try and arrange repair/replacement from the seller.
6/21/2009 11:21:18 PM • Uniden TRU8888... • Answered on Jun 21, 2009
I have a 88 message on my uniden power max 5.8, model tru9480-3. can i get rid of that if the base is not in service.
Page 61 from the Base Unit, there is Delete All. From the handset you have to delete 1 at a time. With.the.phone.in.standby, .press.[ ].to. delete.all.messages..When.the.answering machine asks you to confirm, press [ ].delete again..All messages are. permanently.deleted. https://www.manualslib.com/manual/184807/Uniden-Tru9480-Series.html?page=61#manual ..
12/29/2023 1:04:31 AM • Uniden Lands... • Answered on Dec 29, 2023
I have a UNIDEN AS 8116-2 phone, I have lost the user manual. I need to know how to change handset 2 to handset 1 for UNIDEN AS 8116 phone
Uniden Support - Downloads and Manuals
uniden.info https://www.uniden.info > download Uniden Support - Downloads and Manuals. Missing: 8116-2 ‎' Must include: 8116-2
6/16/2023 4:25:25 AM • Uniden Lands... • Answered on Jun 16, 2023
Uniden EZX290 Expansion Handset Fails Registration to Uniden D1660 Base Unit
Unfortunately, handsets are not universal for Uniden cordless phone systems. The accessory handset for the EZX290 is compatible with the DECT1500, 2000, 2100, 300 and 2900 DECT 6.0 phone systems. The accessory handset for the D1660 is here: https://www.amazon.com/Uniden-D1660-DECT6-0-Cordless-Handset/dp/B004NEUIY2 . I wish that I had better news for you. Unfortunately, the two systems (EZX290 and D1660) don't use same handshake codes. Cindy Wells
5/2/2023 9:42:31 PM • Uniden Lands... • Answered on May 02, 2023
Can I add another uniden hand set to a uniden D1680 series
The Uniden D-1680 system can have up to 12 handsets registered to the base. (The phone system was sold in bundles with 0 to 11 accessory handsets.) However, this cordless phone system has been discontinued. I can only find used DCX160 handsets (the compatible accessory handset) on Amazon and E-bay. I hope this helps. Cindy Wells
3/1/2023 1:07:49 AM • Uniden Lands... • Answered on Mar 01, 2023
Sync 2 versions of Uniden Dect 6.0 to work off the same base.
Yes, you can join an older and a newer version of Uniden Dect 6.0 cordless phones to work off the same base. Here are the steps to sync them:
  1. Disconnect the power cord from the base of both phones.
  2. Take the battery out of each handset.
  3. Wait for a few minutes.
  4. Reconnect the power cord to the base of the newer version phone and insert its battery.
  5. Wait for the phone to register on the base, which should take a few seconds.
  6. Once the newer phone has registered, repeat steps 4 and 5 with the older version phone.
  7. The older version phone should now register on the same base.
  8. Test the phones to make sure they are working properly.
If for some reason the phones do not register on the same base, refer to the instruction manual that came with the newer version phone for further troubleshooting steps.
2/24/2023 10:11:23 PM • Uniden Lands... • Answered on Feb 24, 2023
My mother has a Uniden SS E45 +1 phone and it keeps flashing but there is no message. How do I fix it for her?
It may be that the message is held by the Telco. Phone the supplier and ask. You dial in with a special number and PIN.
2/20/2023 7:15:03 PM • Uniden Lands... • Answered on Feb 20, 2023
Uniden Phone. How to unblock a number please?
Question edited for clarity. Question moved from Computers. Help in the link https://www.google.com/search?q=Uniden+Phone.+How+to+unblock+a+number ..
2/20/2023 7:11:08 PM • Uniden Lands... • Answered on Feb 20, 2023
A uniden phone DECT 6.0. how do i turn on call waiting
Talk to your telephone service provider. There will be a fee. Cindy Wells (Uniden landline phones can make or receive calls; some models have a answering system. Most current models can even check if you have messages on the telephone provider's voice mail. (Sometimes, they'll give spurious voice mail information.) However, they don't have any built-in way of seeing any data (another call) from the telephone provider when the phone is in use.)
1/30/2023 1:22:13 AM • Uniden Lands... • Answered on Jan 30, 2023
2answers
What is the price for uniden model 3x/4246c digital answering machine?
Looks like $65
10/21/2022 3:20:28 AM • Uniden Lands... • Answered on Oct 21, 2022
2answers
Require Datasheet for Uniden Corded Phones
Select the model of your Uniden cordless phone from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl The declaration should be included in the manual.
9/17/2022 8:46:09 AM • Uniden Lands... • Answered on Sep 17, 2022
Uniden TRU8888 Corded Phone Logo
Popular Tags
14 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
anyway reset main base unit tru8888
  • Lands Phones
