20 Most Recent Pinnacle Solene SLP10 Baitcast Reel Questions & Answers
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
5/28/2014 7:31:15 PM • Pinnacle Solene... • Answered on May 28, 2014
2answers
Cant cast the pinnacle platinum plus lp 100
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
8/4/2013 7:39:50 PM • Pinnacle Solene... • Answered on Aug 04, 2013
2answers
How do you get sides apart to lubricate the reel?
Look VERY carefully at the level wind, Usually from underneath. You should find something like a clip or tiny screw holding the tracking pin in place, (jewellers screwdrivers can be handy),
1/24/2013 2:09:40 AM • Pinnacle Solene... • Answered on Jan 24, 2013
My wont lock after casting somr it locks and some
alot of times just needs a good cleaning
6/14/2011 4:05:40 AM • Pinnacle Solene... • Answered on Jun 14, 2011
Wont cast
if u pushed the release button it will automatically lock if u real it wen u are finished casting make sure u put d catch bak on for the line to retrieve to ur reel
3/23/2009 12:25:44 AM • Pinnacle Solene... • Answered on Mar 23, 2009
Where can i find a handle replacement for a Zebco zd3?
get the best deal in zebco spincasting handle when you shop with the best online selection on eBay.com
4/2/2024 3:44:29 PM • Fishing • Answered on Apr 02, 2024
Bass pro bsm 1000H bassmaster professional reel
its an ok reel also comes in left hand version
10/25/2023 7:16:51 PM • Fishing • Answered on Oct 25, 2023
Pinnacle Solene SLP10, 7 bearings bait cast reel. Where can I get a diagram or spare parts for it please?
Question edited for clarity, make and model in correct order. You are correct, these is nothing available. https://www.google.com/search?q=Pinnacle+Solene+SLP10+bait+cast+reel+parts Mike's Reel Repair is the place for all reel repair and parts.
Mikes Reel Repair - Fishing Reel Parts & Service
Mikes Reel Repair https://www.mikesreelrepair.com Fishing reel parts and service and upgrades. We repair rods, reels, trolling motors, depth sounders, downriggers and Coleman Outdoor products.
Reel Parts
Shimano Parts - Abu Garcia Parts - Daiwa Parts - Zebco Parts - ...
Abu Garcia Parts
This section now contains Abu Garcia as well as New Mitchell ...
Reel Tuning & Upgrades
Our Ceramic Hybrid Bearings are spec'd specially for us at the ...
Schematics
2023 Mikes Reel Repair Ltd, All rights reserved. ' Custom ... More results from mikesreelrepair.com ยป
8/27/2023 6:39:01 PM • Fishing • Answered on Aug 27, 2023
White River DCN56 Fly fishing reel. How to change the reel from left hand to right hand retrieve, White River DCN56.
Question edited for full 'make model (what it is)'. The video shows the procedure on two reels. .. https://www.google.com/search?q=white+river+dcn56+parts+diagram ..
7/30/2023 5:27:03 PM • Fishing • Answered on Jul 30, 2023
2answers
Need to find someone that sells Alvey fishing reel parts in Australia.
Check on Ebay
3/12/2023 11:39:16 AM • Fishing • Answered on Mar 12, 2023
2answers
Which Shimano spinning reels are best for catching catfish?
  • #1: Daiwa BG Spinning Catfish Reel.
  • #2: Shimano Stradic FL Spinning Catfish Reel.
  • #3: Penn Spinfisher VI Spinning Catfish Reel.
  • #4: Shimano Sedona FI Spinning Catfish Reel.
  • #5: Okuma Avenger Spinning Catfish Reel.
5 Best Spinning Reels for Catfishing - Buyers Guide - Slo-fishing
and more https://www.google.com/search?q=Shimano+spinning+reels+are+best+for+catching+catfish ..
12/21/2022 3:25:57 PM • Fishing • Answered on Dec 21, 2022
3answers
What is the best fishing rod and reel brand?
St. Croix, Shimano, Shakespeare are popular fishing rod brands and you can choose from these brand without any hesitation. Daiwa, Abu Garcia, Shimano are popular fishing reel brands available in the market. All the product from these brand is durable and high quality and you can purchase from these brands. I have found a pair of an article about the best fishing rods and reels that you can check. Here is the articles: Best Baitcasting Reels brand sandy river buck-1jnjsypw34m5uvf4blk3wpg0-5-0.jpg
11/30/2022 3:36:23 PM • Fishing • Answered on Nov 30, 2022
2answers
How do I choose the best fishing reel size for my needs?
Small Spin Reels: Spinning Reel Size: (1000 or 10)
  • Suggested mono: 1-2kg (2-4lb)
  • Suggested Braid: 4-8lb
  • Common Applications (Guide only): Small fishing reel mostly suited for light fishing in lakes, rivers, bays, harbours etc.
  • Popular for fish type (most common species): Bream, Trout, Whiting.
Choosing a fishing rod to go with this size reel: - As the 1000 or 10 sized spinning reel is quite small, a rod you would typically pair this reel to is one with a length of around 6-7 foot that has a fishing line rating of anywhere between 1-4Kg. Spinning Reel Size: (2000 or 20)
  • Suggested mono: 2kg-3kg (4-6lb)
  • Suggested Braid: 5-10lb
  • Popular for fish type (most common species): Bream, Trout, Whiting, Bass, Flathead, Perch, Luderick.
Choosing a fishing rod to go with this size reel: A 2000 or 20 sized reel being a quite small reel ideally will suit a fishing rod between 6ft - 7ft 6 inches in length that has a line class rating somewhere between 2-5Kg. Medium Size Spin Reels: Spinning Reel Size: (4000 or 40)
  • Suggested mono: 4kg-6kg (8-12lb)
  • Suggested Braid: 8-20lb
  • Common Applications (Guide only): Medium fishing reel mostly suited to lakes, rivers, bays, harbours, light offshore boat fishing etc.
  • Popular for fish type (most common species): Snapper, Morwong, Tailor, Mangrove Jack, Cod, Bone Fish, Barramundi, Mulloway, Drummer.
Choosing a fishing rod to go with this size reel: A 4000 or 40 reel is where you start to gain a little size so this sized reel will generally suit medium action classes of rods in the 6ft-7ft (barra/snapper style rod) with a line class of around 4Kg-10Kg or in an 8ft-10ft (light surf) rod with a light line class rating of around 3-5Kg. Remember this is a guide only to suggest common applications so by all means you can use this reel for several other applications as well.
11/16/2022 5:20:40 PM • Fishing • Answered on Nov 16, 2022
I need diagram of parts
You have not mentioned the diagram requirement for fishing rod or reel but Baitcastingfish is the platform that might help you in this regard as I have found two useful links for you: Labelled diagram of the parts of fishing rod: https://www.baitcastingfish.com/explore-parts-of-fishing-rod-and-their-types/ Labelled parts of fishing reels: https://www.baitcastingfish.com/what-is-baitcasting-reel-explore-parts-of-baitcasting-reels/
11/11/2022 1:49:27 PM • Fishing • Answered on Nov 11, 2022
6answers
How to buy a fishing reel
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
11/11/2022 1:45:31 PM • Fishing • Answered on Nov 11, 2022
2answers
I have a ryobi ad 4000v baitcaster reel won't lock after casting
Hi, Please breakdown and then reconstruct your baitcaster as according to your manual. During the process, take not of any bent, loose or disfigured components. If none, please use a few practice casts. If still not taking, please call your closest sporting goods or fishing store to ask if they can send out a repair man. Thank you.
11/5/2022 2:39:41 AM • Fishing • Answered on Nov 05, 2022
I bought a Shimano 3000EV used electric reel and have operating instructions only in Japanese. I need an English version. Where can I get one?
https://reel-manual.com/shimano-user-manual/shimano-plays-user-manuals/ This site should help you. If not you can get a translating app for the phone and it will translate it for you.
10/30/2022 6:09:17 PM • Fishing • Answered on Oct 30, 2022
Pinnacle Solene SLP10 Baitcast Reel Logo
31 questions posted
Top Pinnacle Fishing Experts
Gloria R. Bloomberg
Gloria R. Bloomberg
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Pinnacle Fishing Expert? Answer questions, earn points and help others
View Most Popular
Pinnacle Fishing
  • Pinnacle Fishing
Most Popular Question
get sides apart lubricate reel
  • Fishing
