20 Most Recent BOSS AUDIO SYSTEMS Boss Ns2 Noise Suppressor Pedal Questions & Answers
I have NS-2 Noise Suppressor
The probable problem is poor connections at the input and/or audio output jacks.
Usually the power supply will fail either on or off which is sometimes cause by a bad input power jack.
In any case, the problem is likely internal and will require repair.
8/6/2010 11:37:19 PM • BOSS AUDIO... • Answered on Aug 06, 2010
I do not get any sound from my ouput, I have it
First, make sure the jack is not shorting against the circuit board or an adjacent wire. Check the wire connections at the jacks and switch. Sometimes these wires disconnect due to poor solder joints on the switch or jacks. Make sure the circuit board is not touching the enclosure or pot assembly.
1/16/2010 5:30:08 PM • BOSS AUDIO... • Answered on Jan 16, 2010
Pedal inputs messed up? just buzzes, no sound!
Here is the schematic:http://www.godiksennet.com/images/sch/NS2.jpg Try testing or replacing Q1 first.
11/26/2009 7:17:11 PM • BOSS AUDIO... • Answered on Nov 26, 2009
I don't know how to set my roland u-20 for using a
The Roland requires a NORMALLY CLOSED contact and that usually cannot be changed.
You will need to reverse the contacts in your pedal to meet that requirement.
OFTEN the pedals have BOTH contacts and you just have to unsolder and move the wire to the opposite contact. This is a common problem
10/30/2009 1:17:39 AM • BOSS AUDIO... • Answered on Oct 30, 2009
Boss noise reduction pedal stopped working for no
The power jack on MANY of the pedals are weak and a yank sideways can damage the jack or the board it is mounted on.
ANOOTHER problem is using an adapter with the wrong size plug. SOME plugs have a larger diameter hole and will work intermittenly.
10/6/2009 3:28:25 AM • BOSS AUDIO... • Answered on Oct 06, 2009
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
9/13/2009 12:59:03 PM • BOSS AUDIO... • Answered on Sep 13, 2009
The treshold needs to be turned all the way up in
Yes. Very much so. The noise reduction should be the very last pedal, of course. Try to even plug your chain in a different outlet than the one your amp (or if recording to a computer, different than the computer outlet). If you have a particularly loud distortion, have it be the last one before the noise reduction pedal.
7/12/2009 6:33:52 AM • BOSS AUDIO... • Answered on Jul 12, 2009
No sound
This is one unit that doesn't seem to have a manual findable online but I did manage to find some vids that may help here:https://www.google.com/search?q=boss+658UA+manual&hl=en&sa=N&source=univ&tbm=vid&tbo=u&ei=eelbUY2nKoHW9ATjwIDwDg&ved=0CHgQqwQ4Hg&biw=1440&bih=756I hope this helps.
4/3/2013 8:35:53 AM • BOSS AUDIO... • Answered on Apr 03, 2013
0answers
My boss amp is on protection mode and it wont work
Likely one of the power amps has failed component(s) and does not achieve electrical balance which then goes to protect mode to prevent damaging your speakers.
You will need to have it serviced.
12/25/2009 11:10:14 PM • BOSS AUDIO... • Answered on Dec 25, 2009
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
BOSS AUDIO SYSTEMS Boss Ns2 Noise Suppressor Pedal Logo
9 questions posted
Top BOSS AUDIO SYSTEMS Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a BOSS AUDIO SYSTEMS Music Expert? Answer questions, earn points and help others
View Most Popular
  • BOSS AUDIO SYSTEMS Music
Most Popular Question
ns 2 noise suppressor
  • Music
