20 Most Recent BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal Questions & Answers
0answers
0answers
Battery problem
DId you remove the plug from the input jack to turn the pedal off? If so then you may have a bad input jack.
7/4/2013 4:43:53 PM • BOSS AUDIO... • Answered on Jul 04, 2013
0answers
Loss of volumn
Be the first to answer 11/2/2012 12:53:32 PM • BOSS AUDIO... • Posted on Nov 02, 2012Be the first to answer
My light turns on, can't switch it off, no effect
First thing is to check that powr adapter is the correct one and/or battery is good. Light will come on with near dead battery or wrong power adapter... Wrong adapter can damage the unit.
9/27/2012 6:38:21 PM • BOSS AUDIO... • Answered on Sep 27, 2012
Why is my vintage boss dd-3 very quiet on the repeats even when level is turned up full?
Assuming you have the feedback level turned up....can you hear any difference at all when adjusting the feedback?
8/19/2012 3:29:48 PM • BOSS AUDIO... • Answered on Aug 19, 2012
My boss DD-3 makes a
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
4/3/2011 3:13:43 PM • BOSS AUDIO... • Answered on Apr 03, 2011
Need replacment inputs for boss digital delay
the jacks are not diffiult to find nor to install, but don't buy cheap radio shack jacks, go to a good music store and buy jacks ( the price may be 3 to 5 dollars each). take the unit apart and take not of where the wires go, wirte it down/draw a diagram, note colors of wire and where they go. cut the wires loose and take the old jacks out, then solder in the wires where they belong, and you're good to go.
3/20/2011 11:59:54 PM • BOSS AUDIO... • Answered on Mar 20, 2011
My Boss Digital delay pedal won't stay on unless I
This is likely a failing switch under the pedal. Either the toggling mechanism is broken in it or if it is a momentary type it probably has "contact bounce" that exceeds the what the de-bounce circuitry can handle.
3/8/2011 9:20:12 PM • BOSS AUDIO... • Answered on Mar 08, 2011
My DD3 pedal doesn't work.
Check all connections including the battery clip if you use a battery, and the adapter jack if you use the AC adapter. Also check you guitar cable connections as the pedal turns itself off if the guitar plugs have a loose connection. Make sure the guitar jacks on the sides are tight and don't need tightening. Any of those issues could cause the pedal to operate sporadically or not at all.
It could also be and IC problem internally on the pedal's circuit board, but before you open anything, check all the connections non electrical issues can occur more often on pedals.
2/19/2011 9:01:57 PM • BOSS AUDIO... • Answered on Feb 19, 2011
Used Wrong trasformer. BossDD3 still in working
You likely fried the input filter capacitor... it is where the power comes in and on one of the schematics it is C51 which is a 100 MFD/16 volt electrolytic. Also a Zener labeled D6 MIGHT be gone... it is in parallel with that cap. Also the 78L05 May have been degraded, but this is a remote possibility.
The pedal has a lot of hardware to run from a 9 volt battery and I would NOT exoect much life out of one.
9/25/2010 2:13:16 AM • BOSS AUDIO... • Answered on Sep 25, 2010
When guitar is plugged in
Most probable cause is low battery or defective power convertor if battery is not used.
8/31/2010 4:54:18 AM • BOSS AUDIO... • Answered on Aug 31, 2010
BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay Pedal Logo
Popular Tags
32 questions posted
Top BOSS AUDIO SYSTEMS Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a BOSS AUDIO SYSTEMS Music Expert? Answer questions, earn points and help others
View Most Popular
  • BOSS AUDIO SYSTEMS Music
Most Popular Question
battery problem
  • Music
