20 Most Recent Lexicon Lambda 4x2x2 USB Audio Interface Questions & Answers
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Lexicon Lambda... | Answered on Apr 28, 2011
The best way is to un-install the software and re-install it with the English option... this is the ONLY practical way. Use the "ADD//REMOVE" programs in the control panel.
Lexicon Lambda... | Answered on Apr 10, 2010
You likely have not got the driver installed correctely. In Windows type machines OFTEN you must install the software driver BEFORE the device is tied to the computer. It sounds like you are on an Apple machine. Look for cautions regarding connection before software is installed.
Lexicon Lambda... | Answered on Apr 06, 2010
Try downloading Asio4all at http://www.asio4all.com/ and carefully following their instructions. There is good information under the FAQ/Troubleshooting section on their site. Id also recommend joining Recording Review for some great info. I think you can reach them through recordingrev001@aweber.com. Hope this helps.
Lexicon Lambda... | Answered on Jul 10, 2009
you SHOULD be able to.
Just use Direct Sound in the host tab.
Lexicon Music | Answered on Mar 19, 2017
Hello Rita, I sent you the link, where you can make the purchase of the manual online
I hope you can buy the Manual
Greetings Franco Dosil
Hola Rita, te envio el link, donde puedes hacer la compra del manual por Internet
Espero puedas comprar el Manual
Saludos Franco Dosil
http://www.wdgreenhill.com/manu/baldwin_a.htm
Music | Answered 9 hours ago
I understand your pain - was googling for similar, and came across this post, 5 years prior. My SGC Nanyo Bass Collection has just started to play silly beggars with the pots, and a bridge fault. Nowhere online seemed to have any details of the wiring, as the problem is, as you say, the fact that all of the tone and volume pots are based on a printed circuit board. If theres a nick or short on the board, its a pig to replace, and I really wouldn't like to have to wire any pots onto it. I'm currently looking at the options of ripping out the old electrics and wiring it from scratch myself. If you're still after answers, good luck!
PS - noted that none of the previous replies are relevant to this - mostly going on about the amps or a Fender guitar??!
Music | Answered on May 17, 2019
you will want to try manufacturer or online search
Music | Answered on May 14, 2019
Lexicon Lambda 4x2x2 USB Audio Interface Logo
Popular Tags
4 questions posted
Top Lexicon Music Experts
Michial Gueffroy
Gil Shultz
tmaree
tmaree
Are you a Lexicon Music Expert? Answer questions, earn points and help others
View Most Popular
Lexicon Music
  • Lexicon Music
Most Popular Question
omega lambda lexicon vocals
  • Music
