20 Most Recent
Fuller Brush FBHD1 Bagged Upright Vacuum Questions & Answers
Lack of Suction and roller not working
Replace your belt. Its probably stretched or broken, also check the bag for fullness and the hose for clogs. let me know if you are still having trouble.
I have a cannister vacume,
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
How do i fix a vacuum line hose on a car that's been cut?
Alot depends on the type of hose. There are plastic hoses and rubber hoses. Generally you can use a smaller plastic connector to connect two rubber hoses together and visa versa, Make sure it is a snug fix. You could also use an adhesive to keep it together.
3/31/2024 3:39:13 PM •
Vacuums
Answered
on Mar 31, 2024
How to empty a etl vc-h3301 vacuum cleaner
How to open it to see if the fuse is blown. I removed the three screws I saw. I feel that there is another which prevents me from opening it in two. I looked under the tights, I removed the plate where the two buttons are located. I can't open it.
3/21/2024 4:57:04 PM •
Vacuums
Answered
on Mar 21, 2024
