20 Most Recent
Sharper Image Electric Wine Opener - WSI-OP200 Questions & Answers
Won't extract cork
I have the same type of device and I replaced the battery pack with Nickel metal hydrate batteries off eBay, cost about $10.00. Of course I had to make up the cell pack and install and solder the battery pack in.
Wsi-op200 won't hold charge
The short answer is: buy a new one. The long answer is: the battery can be replaced with a
ATC Cordless Phone Battery 3.6V NiMH for Sanik 3SNAAA55HSJ1 3SNAAA60HSJ1 series (amazon, $3.16)(this battery is the correct size and volt, but has a higher milliamp rating) This, actually, is a battery for a cordless phone. The old battery is not meant to be replaced, but this one will work. To do this: 1) remove the base from the unit, 4 screws can be removed with a long narrow Philips head screw driver. you can insinuate the driver into the corkscrew area. 2) pry off the black switch, this can be done with a small flat screwdriver. 3) slide off the silver sleeve from the unit. 4) separate the black plastic clamshell pieces by removing four screws. 5) remove tape form battery and cut wires next to battery. 6) use a dremmel grinder to create more space at inner side of plastic base part(battery will not allow unit to close as it is flat and OEM battery is curved) 7) solder battery leads to unit leads(electrical tape to cover solders). 8) screw unit together. 9) put axle for switch back into place and slide silver sleeve back over unit.(may need some lubricant and coaxing) 10) screw base back to unit(may need to carefully tape screws to driver so you can get them into place 11) recharge(1-2 hours of work).......or BUY A NEW UNIT.
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
