20 Most Recent
Camelbak ThermoBak 3L Questions & Answers
I filled with water and
has the valve split opened up? you\'ll need to do that first. suck on it to pull the water through
3/27/2014 3:17:05 PM •
Camelbak...
Answered
on Mar 27, 2014
Are you supose to fill
you can. i would suggest only a quarter full. however the caps on them are large so icecubes can be inserted into them to help keep the water cold for longer
3/27/2014 3:07:04 PM •
Camelbak...
Answered
on Mar 27, 2014
My bite valve leaks after
camelbak have a full range of replacement accessories for their pack range. i can suggest buying the connector that has the small lever lock so you can shut off the flow regardless of the condition of the mouth piece
3/27/2014 2:57:45 PM •
Camelbak...
Answered
on Mar 27, 2014
Thermobak 3l omega - is
there is usually a zip access on the packs that allow full removal of the bladder for cleaning.
3/27/2014 2:56:37 PM •
Camelbak...
Answered
on Mar 27, 2014
I got a camelback as
The soft tip should have a **** in it, that is the opening that the water is delivered from. Usually it does a very good job of sealing itself. Simply put the mouth piece in your mouth with the **** vertically and bite on it. They work off gravity feed.
7/17/2011 3:24:06 PM •
Camelbak...
Answered
on Jul 17, 2011
How do I fill with water
In the main sac part of the camelback, pull the velcro fastening apart at the top of it and slide out the bladder from the inside. There is a twist cap, undo this fill with water, slide the bladder back into the camelback to ensure you don't overfill it.
Fastent he velcro at the top and bite the mouth peice to drink the water.
Vote for me :)
7/14/2010 11:45:04 AM •
Camelbak...
Answered
on Jul 14, 2010
Water has a mildewy taste after some usage. Whats
Several ways.All require complete flushing afterwards.A little vinegar added to the water.A little lemon juice(my favorite) least desirable, a little bleach.Flush thoroughly afterwards.Good Luck
3/31/2009 10:43:32 PM •
Camelbak...
Answered
on Mar 31, 2009
