20 Most Recent
Fmi Fireplaces SDVBPD Direct Vent Propane Gas Burner and Logs SDVBPD Questions & Answers
36ECMII pilot light won't light
If you go to this link
http://fmisupport.hcents.com/supportdocs/54024F.pdf it will take you straight to the owner's manual.
Now the gas log set is completely seperate from the fireplace. You would need to find out the model of the gas log set as any manufactuer of vented gas logs can go in this fireplace. Just for clarification the brand is actually Coleman but it was made by FMI. Now, the SPVBPD is a direct vent gas log set that was only designed to go into either the Amity, Oxford, or Victor hearth gas stoves. If you have the SPVBPD burner in a 36ECMII then you honestly need to remove that log set, as it was a burner only rated for direct vent fireplaces, and get a set of 18" LP vented logs. If you look at the link below you will see the owner's manual for the SDVBND. These logs need to be removed and you can go with any 18" vented log set. I suggest Peterson (
http://www.rhpeterson.com/realfyre/vented-series/)
as they have the widest selection of logs and biggest array of dealers. Good luck.
Desa Tech SDVBND Owner Operation And Installation Manual
My sloan flushmate toilet makes
this has already been answered on another site click here
http://www.landscapetutorials.com/tips/flushmate-noise.htm
the repair is done by
Fortunately this problem is very easy to cure. Simply follow the instructions below.
- Remove the ceramic cover from the tank on the back of the toilet.
- Fill a one-gallon jug with water.
- Pour the water into the toilet tank. Just pour it over the top of the black plastic Flushmate container. It will run down the sides into the bottom of the ceramic tank. See photo below.
- Now flush the toilet. The noise should be gone.
if you have any further questions please message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
3/14/2024 9:14:14 AM •
Home
Answered
on Mar 14, 2024
How to fix clock
Do you have the manual with you?
2/9/2024 2:57:33 PM •
Home
Answered
on Feb 09, 2024
