20 Most Recent Garmin NUVI 255 PERSONAL GPS Device Questions & Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Garmin NUVI 255... | Answered on Aug 15, 2010
Tip
Download Nuvi 255 Manual
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Have you lost your User's Manual or the Quickstart Guide for your Garmin Nuvi 255 or 255W GPS?
Would you like a digital copy for easy searching of terms and quick reference?
Both manuals are available in pdf format, just follow the photo links below:
I hope that helps.
on Apr 16, 2010 | Garmin NUVI 255 PERSONAL GPS Device
Are you sure you have set the mark correctly. 30 ft would be acceptable due to regulations , but 2 miles is quit a lot of variance. Check to be sure your map is up to date as some maps were never updated with road changes if you are going off a pre-set map load
Garmin NUVI 255... | Answered on Mar 09, 2010
When you first tun them on it is supposed to tell you to touch all four corners in a row.....this calibrates it. Yours may be differenr but the most of them are this way.......
Garmin NUVI 255... | Answered on Dec 25, 2009
If you are pressing the on switch and it is not switching on then try plugging this in someone else's care and see if it works. If it doesn't then there is an issue with the unit or the charging cord. Try a different cord and if that doesn't fix it then it is the unit. Good luck.
Garmin NUVI 255... | Answered on Jul 16, 2009
Press the reset button - you'll find it on the lower right of the Nüvi 255, but it doesn't look like a button. It's basically the sticker with all the information on it. It's just enough to push the sticker carefully with something small, not too sharp so it doesn' get destroyed. The Nüvi reboots, the loader loads and proceeds with the software load. Once this is over, shut down the Nüvi and reconnect to the PC. Then, everything works fine (it did at least for me).
Garmin NUVI 255... | Answered on May 22, 2009
You charge the unit via your cigarette lighter socket using the charge lead supplied. Generally you type a zip code if you know it and the satnav will calculate your route.\if you dont know the zip code type in an address but this gives several areas. Zip codes are preffered.It will talk once you start driving giving you forwarning of any turns you need to make in advance. Good Luck
Garmin NUVI 255... | Answered on Mar 17, 2009
if you have the feature (map updates) included with the model you purchased, first you have to download and install Garmin Express on your computer, and then connect your GPS to the computer.
the computer should detect the GPS and synchronization instructions should appear.
Garmin GPS | Answered on Jul 12, 2019
Shut it off, wait a few, turn it back on, press all four corners with fingertips at the same time. If that doesn't re-set it, call Garmin. They're super helpful
Garmin GPS | Answered on Jul 06, 2019
Garmin NUVI 255 PERSONAL GPS Device Logo
Popular Tags
12 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
Garmin GPS
  • Garmin GPS
Most Popular Question
says low battery charge
  • GPS
