20 Most Recent One For All URC-7800 Remote Control Questions & Answers
2answers
I'm looking for codes and procedure to program my oneforall urc-4041 remote to my sony blu-ray BDP-S350
Blu-Ray players cannot be set-up with any universal remote controls. It must have its original one.
8/19/2016 7:37:40 PM • One For All... • Answered on Aug 19, 2016
Need one for all prog. code to magnavox blu-ray
You can't control its Blu-ray region with a universal remote control. Can adjust its DVD region, with a URC. 0029,0021,0274,0279,0270 are the codes to check. If you wish to get more codes and other details, http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/
12/26/2013 1:30:54 PM • One For All... • Answered on Dec 26, 2013
0answers
URC176000-01R00
Be the first to answer 12/22/2013 3:18:54 AM • One For All... • Posted on Dec 22, 2013Be the first to answer
0answers
URC176000-01R00
Be the first to answer 12/21/2013 6:13:52 PM • One For All... • Posted on Dec 21, 2013Be the first to answer
0answers
Need cods
  1. Turn on the component you wish to control
  2. Press the button for the device you want to program.
  3. Press and hold the [SETUP] button until the LED flashes twice.
  4. Enter the code 9-9-1. The LED should flash twice.
  5. Alternate between pressing the [POWER] key and the device key until your device shuts off, or use [PLAY] for VCR, LD, CD and DVD players. This may take some time as there are hundreds of codes.
  6. When your device turns off, press the [SETUP] button to save. After you have configured your devices using the Code Search feature, you might need to find out which code was assigned.
  7. Press the button for the device you want to program.
  8. Press and hold the [SETUP] button until the LED flashes twice.
  9. Enter the code 9-9-0.
  10. Press the numeric button [1] and count the number of times the LED blinks. This represents the first digit of the four digit code. Press [2] for the second digit, [3] for the third digit and [4] for the fourth. If the LED does not blink, the number is 0.
I’m happy to help further over the phone at https://www.6ya.com/expert/al_e83b1941f9c0f302
2/19/2011 12:30:56 AM • One For All... • Answered on Feb 19, 2011
Have one for all
Try 0054, 0030, and 0171.
8/22/2010 12:57:46 AM • One For All... • Answered on Aug 22, 2010
I need the code for
HI,
The code for RUC 7800 remote to programme with sony TV is 0000
Thanx
7/28/2010 3:17:54 AM • One For All... • Answered on Jul 28, 2010
Trying to program a universal remote to scientific
If you have a URC-7800 the codes 0477, 0008, 0017 should work for the scientific atlanta cable box.
2/5/2010 3:56:37 AM • One For All... • Answered on Feb 05, 2010
Need Scientific Atlanta 8300HD DVR code
You can follow the two methods I have explained below:
AUTO SEARCH FOR CODE
To program your remote in Auto Search Mode, first turn on the device you wish to program and point the remote toward it.
Then press and hold the SET and POWER buttons until the LED turns on.
Then press the device key ( CATV or RCVR) .
The LED will flash once.
Then press the CH+ button.
Then hold the POWER button for about two seconds until the LED turns on.
Release the POWER button and the LED will flash slowly. Your remote is searching through all of the codes. Continue to point the remote at the device until your device responds.
If your device turns off, turn it back on and press the CH+ button on your remote. Then press the POWER button and CH+ button alternately until the device turns off and the code is correct. Press the ENTER button to confirm and store the code. The LED will flash three times and then turn off.
If the above is not helpful then try manually searching for code:
First, press the device button on your remote.
Then press and hold the SET button. While holding the SET button, press 1 to find the first digit, 2 to find the second digit or 3 to find the third digit.
The LED flashing time will stand for each code number. If it doesn’t flash, it will stand for zero.
For example, the TV code you are trying to find is 102.
Press the SET button and 1. The LED will flash one time.
Press the SET button and 2. The LED will not flash.
Press the SET button and 3. The LED will flash two times.
Hope it helps to find your code. Thank you for using fixya!
9/25/2009 5:54:30 AM • One For All... • Answered on Sep 25, 2009
CODE FOR HATICHI TV
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC7800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
6/24/2008 6:12:24 PM • One For All... • Answered on Jun 24, 2008
tip
Programing your remote controller
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-vcr.shtml#dvd
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash radidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programing your remote can be found here: http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
2answers
Need code for trisonic ts-rc411
I tried all the codes on my remote and none has worked on this remote tsrc411. Help
1/22/2024 7:50:24 PM • One For All... • Answered on Jan 22, 2024
Daenyx model DV833B, I need the remote code for DVD player please?
Question edited to a lot more clarity and fix your broken Spacebar! https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 0872 is the code
Daenyx DVD universal remote control codes (4 digit)
eliztech.com https://www.eliztech.com > remotes > codelists > daen... Mixed Daenyx DVD codes from a single brand of universal remote control. Highlight / Show only codes for: OneForAll x. Sort codes Show color. 4 digit codes:. ..
6/1/2023 5:04:49 PM • One For All... • Answered on Jun 01, 2023
Circuit diagram videocon bazoomba flat 29" 1200w
????????? TV WOFAR SARKIT
11/25/2022 2:18:57 PM • One For All... • Answered on Nov 25, 2022
2answers
Where i shall find a fujitec air condition remote control?
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/. Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
7/10/2022 8:03:08 AM • One For All... • Answered on Jul 10, 2022
One For All URC-7800 Remote Control Logo
Popular Tags
18 questions posted
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • One For All Televison & Video
Most Popular Question
39 m looking codes procedure program
  • Televison & Video
