20 Most Recent Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Questions & Answers
I suppose you mean the oil in the Trim system...
Lift the engine all the way up,
Place the jackstand to keep the engine fully up.
You'll see a plastic plug in the center cylinder.
Unscrew that plug. ( There can be some pressure, take care of your eyes!)
Fill with ATF-oil till the level is at the bottom of the plug hole.
Screw the plug back in.
Lower the engine.
Done!
Clymer... | Answered on Oct 04, 2016
known as maintenance !! they dont clean them selves and more you use them more times you need to check and clean them ! unless they have shorts or damaged wires etc these engines are simple and reliable ! if your getting lots of dirt under the flywheels then check the top crank seals not leaking as this will foul the contacts also !
Clymer... | Answered on Jun 25, 2015
Have you replaced the impeller in the lower unit recently? If so was it in pieces? I would start there.
Clymer... | Answered on Jan 28, 2015
Red battery positive
Red purple, switched positive
Yellow red startermotor connect to positive to start )
Purple white choke (connect to positive to choke)
Black yellow stop circuit ( connect to negative to stop engine )
Black battery negative ( for stop circuit )
Clymer Boating | Answered on Oct 04, 2017
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
I think you have to look at a fuel supply problem. Clogged carbs or bad fuel pump...
Also have a look at your spark plugs...
Clymer Boating | Answered on Sep 25, 2017
clean carbs and check set up !
Clymer Boating | Answered on Jun 04, 2014
Vinegar and water. Polish with a microfibre cloth. See the videos
https://www.google.com/search?q=remove+sunspots+off+of+a+fish+finder
Boating | Answered 13 hours ago
Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Logo
11 questions posted
Top Clymer Boating Experts
Colin Stickland
Colin Stickland
yungtek
Level 1 Expert
Bruce
Are you a Clymer Boating Expert? Answer questions, earn points and help others
View Most Popular
Clymer Boating
  • Clymer Boating
Most Popular Question
top up lubricating oil in hydraulics
  • Boating
