20 Most Recent
Buck Legendary: The Box for Xbox 360 Questions & Answers
The power button has a blinking red light, what
4 flashing red light = av cable not connected. double check id av cable is connected properly. try using different av cable.
3 flashing red light = hardware problem . may require repair
2 flashing red light = overheating
1 flashing red light on bottom right LED with error code = hardware failure may require repair
My x-box is laying flat and the bottom right
You are currently experiencing the infamous Red Ring of Death or "RRoD"
This is a hardware malfunction within early xbox 360's and will require you to send the console to Microsoft for repairs.
Reference to issues are
HERE
sorry, but this is not repairable, but hardware must be replaced.
Luckily Microsoft has been repairing the units for free.
good luck
X box live bad internet connection nat closed
The problem is your router, and/or your isp, the nationalities you are allowed to connect to are limited, to fix this you will need to first call your isp and ask about nat conections, and if that does not solve the problem then you will need to go into your router settings and change your nat setting, how to do this will be outlined in yoru routers manual.
Xbox 360 will not read disk
common problem with your disk drive you need to clear your cache to do this go to system setting then memory then hover over your hard drive then click y then click clear system cache call 1-800-4my-xbox if this does not work for you
73+1021 erorr in my x box 360
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
X Box 360 3 red rings
check xbox.com/support or call 1-800-4MYXBOX .
They have troubleshooting steps for you.
But heads up, you might need to send it in for a repair.
My x box is not working the green light is coming
if you have the disc read error then try a cd lens cleaner disc that has a brush and the solvent. bout $5 at walmart. if it continues after that then you might have to send it off to get it fixed. but mist times its just a dirty lens that can be fixed real cheap and no waiting 2 weeks to get it back.
Have sound but no vedio on x-box 360
well all i can think of is that you mite have it on the wrong input or you vedio cables may need to be replaced. some friend of mne had to chage out there cables to so hopefully this helps you if not im sorry.
good luck :)
EnVy
My x box will play cd's and dvd's but not games.
Here's how:
1. Carefully open the Xbox by removing the torx screws and then releasing the clips that hold the case together. The clips and molding pieces all come off easily; pry them open carefully.
2. Load the flash firmware disc into the DVD drive and power off the Xbox.
3. Disconnect the DVD drive from the SATA cable and note the brand of drive used in your Xbox. Currently Microsoft uses Hitachi, Phillips and Toshiba DVD drives in the Xbox 360. Only the Toshiba and Hitachi drives have firmware updates.
4. Connect the DVD drive to your PC with a cross-wired SATA cable interfaced to a compatible SATA port. Confirm that the video cable is connected to the Xbox so that it won't turn off during the flash process.
5. Hold the two loose wires of the cross-wired cable together and press the "Start" button on the Xbox. Separate the wires immediately when the green light begins to flash on the front of the Xbox. The light will begin to flash quickly and the drive will begin to spin as it enters mode "B."
6. Turn the PC on and allow it to fully boot from the DVD drive. If Windows appears to fail the boot, eject the DVD and it will finish booting. You've successfully flashed the drive.
7. Reassemble the Xbox and enjoy playing the backup of your favorite game.
Sources: http://www.ehow.com/how_2316522_flash-xbox-dvd-drive.html
Xbox 360 has trouble reading games and dvd`s keeps
The dvd drives tend to have issues. make sure your discs are clean and not scratched. If they are badly scratched use an automotive cleaner / wax to gently polish out any scratches.
if the DVD drive is still not working the drive is replaceable. replacement drives are readily available on ebay, do an internet search on how to swap the drive.
If you are not familiar with opening a computer case and replacing components in it I would let someone who is familiar with the process do it for you.
Hope that helps
My x box has three red rings
Sorry to
hear this, seems you may need to have the motherboard fixed, do to this you
need to take the xbox360 apart then reflow the board.
there is a
great 6part video guide on YouTube to view for free. 6 videos from the same
fellow, each video is a few mins long, and goes over everything for you.
http://www.youtube.com/user/ohiocitysales#p/u and its free unlike some eBook site.
I actually
used the same method to fix over 450 Xbox360 units with no problems at all,
barring a few (but i have done nearly 500 so you expect a few problems along
the way), you just need a few things though like a heat gun and some thermal
paste. sounds hard, but it's very easy once you start!
Hope this
helps in some way.
