20 Most Recent Swisher E4 Swindaiwa 24.5cc 4-Stroke Engine Commercial Grade Articulated Hedge Trimmer #E4-HT4000 Questions & Answers
Model LS722 swisher what kind of oil
1/25/2023 5:08:05 PM • Swisher Garden • Answered on Jan 25, 2023
Where to find hydrostatic pumps
Likely its a hydro-gear, available from multiple sources.
9/23/2022 1:16:11 PM • Swisher Garden • Answered on Sep 23, 2022
I have a Swisher 2560 zero turn riding mower that when I ride to cut with it it hops I don't know why if anyone can help please
Swisher ZTR steering arm is a poor design and loosens over time which eventually causes control issues. If the steering arms flop about, the main pivot bolt needs tightened.
4/13/2022 10:05:13 AM • Swisher Garden • Answered on Apr 13, 2022
Replaced the blade drive belt on my Swisher Finishing Touch 42" walk behind. Now that the new belt is installed, I turned the mower on and the pulley that spins the blade drive belt is not spinning.
It sounds like the belt was installed wrong or not adjusted assuming it is the correct replacement.
10/2/2021 2:34:42 AM • Swisher Garden • Answered on Oct 02, 2021
Can a bad battery cause clutch to slip?
Not likely. But to eliminate that possibility try connecting a battery charge to the battery and try engaging the blades then. Also check all electrical connection in system for corrosion and tightness. Lastly With compressed air blow all dirt and debris from the mower, especially clutch area and Hydraulic pumps. Check tension on blade drive belt.
10/17/2018 1:38:52 AM • Swisher Garden • Answered on Oct 17, 2018
How much oil does my swisher mower take as I am changing the oil!
need to know the engine make and caopacity the operators manual will have the capacity required
9/10/2018 10:30:04 PM • Swisher Garden • Answered on Sep 10, 2018
Have a swisher trim and mow model st67522e will not start unless I spray primer in carburetor. Already cleaned carburetor. Runs once primed but will not start when shut down . Have to prim again to get started.
Check the fuel jet and make sure it is clean. If there is any dirt in it even though you cleaned the carb the unit will not run properly if any at all. I use an air compressor to clean mine ore a real fine piece of wire.
4/2/2018 7:30:06 PM • Swisher Garden • Answered on Apr 02, 2018
Swisher E4 Swindaiwa 24.5cc 4-Stroke Engine Commercial Grade Articulated Hedge Trimmer #E4-HT4000 Logo
Popular Tags
0 questions posted
Top Swisher Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a Swisher Garden Expert? Answer questions, earn points and help others
View Most Popular
Swisher Garden
  • Swisher Garden
Most Popular Question
countax c400h honda v twin engine over
  • Garden
