20 Most Recent
RTO Accugreen 1000 Drop Spreader Questions & Answers
Spreading lime
Depends on how acidic your lawn is have you taken some samples to your farm and garden center to have it checked A local coop could also send in samples for you that way you will have accurate idea of how much you need.
I have a accugreen 1000. The wire for the settings
You can try to calibrate the spreader, tightening the screw at the end of the control wire should fix the situation. If calibrating the spreader does not help please call us at 800-543-8873 for more assistance. To Calibrate the Accugreen 1000: 1. Adjust the micrometer setting to a 6. 2. Flip the spreader over. 3. Use your foot to squeeze the trigger against the handle. 4. The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper. 5. To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insect.
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Stops running after warms up
It's eithe your coil ha heat soak and needs replacing or your fuel circuit isn't venting properly and is creating a negative pressure
11/22/2013 10:43:17 AM •
RTO Garden
Answered
on Nov 22, 2013
