20 Most Recent
Vtech VT 2461 Cordless Phone Questions & Answers
How to change my handset
There's a tone/pulse switch on the bottom of the base unit. If you need a manual, you can download one at
http://vt.vtp-media.com/ecp/documents/product_Product/1249/UserManual/2839/vt2461_manual.pdf
I hav a vtech cordless
The answering machine instructions begin on page 30 of the manual at
Phone changed from tone to
There's a switch on the bottom of the base unit to switch between tone and pulse. It's marked "18" in the illustration on page 6 of the manual at
Model 2461 - "check
Power light indicators on flashing red as warning that battery is almost depleted of functionality. ascertain that devices with extension cables deriving power from elsewhere are plugged in to reattain power to acheive regular functionality. For example, devices with red light indication as power warning would also flash yellow or green when in full power charge from another source. refer with devices user guide or manual for refering, diagnostics.
What does "check AC" mean
AC stands for alernating current usually recognisable with the devices power cables. Check with the devices power cables if not broken would require ascertainments that has been connected to the power outlets.
Can you retieve deleated messagegs from your phone
Hello! The answering machine will automatically save messages if you do not delete them; Even in the event of a power failure. It can hold 15 minutes of messages. After 15 minutes machine will "wrap" writing over the oldest message. An old message (listened to) can be deleted by holding erase for more than two seconds. Pressing Mailbox X (1-3) will delete all Old Messages in that box. Once deleted they are gone forever...
Guru.........saailer
I’m happy to help further over the phone at
https://www.6ya.com/expert/david_6df67de3b14de867
VT2461 ADDITIONAL HANDSET PROBLEM
I can vouch for the second solution. It worked perfectly on my 2461 with two extensions. Even the vTech website was not able to provide a solution.
My VTech 2461 cordless phone is stuck on Pulse
To switch back to tone dialing, hold down the SELECT button for couple of seconds. The display on the base unit will read PU indicating pulse dialing. Now press and hold SELECT to change it to TN (Tone dialing).
